Quick question about spark plug wires
  • kz750saskatoon
  • kz750saskatoon's Avatar Topic Author
18 May 2011 12:43
#451901
I just got some grey Dyna coils that I will be installing shortly. I'm also wanting to change the spark plug wires. I was going to use these ( www.z1enterprises.com/detail.aspx?ID=208 ) since I have no need for suppression.
My question is about connecting the wires to the dyna coils. The inside of the secondary tower looks smooth with one notch in it. Is there a name for this type of termination? I'm not having much luck with Google and I don't want to look like a pud when I go to order the cables from a local shop. (I'd order from Z1 but being in Canada makes it expensive to do small orders from Z1.)
1981 KZ750-H2
Saskatoon, SK
  • RedlineJunkie
  • RedlineJunkie's Avatar
Re: Quick question about spark plug wires
18 May 2011 13:02
#451904
Just tell them that you need wires with 4 male and 4 female terminals. The terminal that goes into the coil is considered a male terminal.
Terminating plug wires can be a major bitch. I suggest getting a good ratcheting terminating tool. The hammer and vise style dies that come with many kits take some practice.....
  • dshelly
  • dshelly's Avatar
18 May 2011 13:30 - 18 May 2011 13:32
#451910
Just go to your neighborhood auto parts store and get a set of terminal crimpers that have the 7 or 8mm spark plug wire slot in them. Strip the wire back, fold it back on itself , slide the terminal on and crimp it. Piece if cake! Oh yea, don't forget to put the boot on first or you'll really fell like a dumb ass.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Last edit: 18 May 2011 13:32 by dshelly.
  • OnkelB
  • OnkelB's Avatar
18 May 2011 16:06 - 18 May 2011 16:07
#451930
kz750saskatoon wrote:
...My question is about connecting the wires to the dyna coils. The inside of the secondary tower looks smooth with one notch in it. Is there a name for this type of termination? I'm not having much luck with Google and I don't want to look like a pud when I go to order the cables from a local shop...
Don't know the name of that type of termination, but if you buy a set of Dyna wires the terminals are included as are the boots that cover the connections at the coils. Just cut the wires to desired length, do as Dshelly suggests above and there you go.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 18 May 2011 16:07 by OnkelB.
  • kz750saskatoon
18 May 2011 16:20
#451933
Thanks for the information.
1981 KZ750-H2
Saskatoon, SK
  • MFolks
  • MFolks's Avatar
18 May 2011 16:30
#451939
A little rubbing alcohol works pretty good as a lubricant when sliding the rubber boot over the sparkplug wires. Give the boot a twisting action when putting it on.
