wiring question
  • Frankn9
  • Frankn9's Avatar
Re: wiring question
05 Mar 2011 21:19
#435392
I'm pretty sure that cable should not be there, get rid of it and move on. some people feel that because the electrical panel is mounted in rubber bushings that they need an extra ground.
  • stonemaster
  • stonemaster's Avatar Topic Author
Re: wiring question
05 Mar 2011 21:29
#435395
AGREED THANX B)
  • stonemaster
Re: wiring question
06 Mar 2011 10:00
#435502
I dug out the old wiring harness in an effort to understand, I rediscovered some of the issues possibly causing the extra ground. A couple of the connector block in the wiring panel appeared to have been burnt pins in them, these had been bypassed into the harness wiring. I'm beginning to come to the conclusion that a ground problem cause a partial frying of the wiring hence the addition of the extra ground, i am now considering using this extra ground as a precaution, thoughts ???
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
Re: wiring question
06 Mar 2011 18:18
#435717
If you have it cleaned up good, I would think it wouldn't be needed, but really, what could it hurt as long as you know why it's there and don't use it as a crutch not to keep everything bonded good? And besides, then if you lose your pos. cable you have a spare already bolted to the frame.:laugh:
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • stonemaster
Re: wiring question
06 Mar 2011 18:40
#435723
funny u should say that, I know guys that ride Ironeads that run the second throttle cable just in case they break one out on the road ;)
  • jjdwoodman
Re: wiring question
06 Mar 2011 19:37
#435740
Yep, I've seen those! How long till you think you'll be driving that spare wire around?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
