81 kz550 no start
Re: 81 kz550 no start
07 Feb 2011 19:04
If there's a convenient motorcycle dealership nearby, especially a Kawasaki dealership, they might have a Kawasaki Coil Tester available to test the existing coils, especially the suspect coil.
The tester is superior to an ohm check, because it measures the actual spark intensity produced by the coil.
Likely would be no charge for the test (in hopes of selling a new coil at stealership prices).
If it passes the test, Hooray.
If it fails
, thank them and get price of a new coil :pinch: , but don't purchase.
Shop around, and likely confirm Z1E as best source.
If going to Dyna-S ignition, Z1E lists the Green green 3 ohm coil recommended by Dyna for using with Dyna-S, and Z1E also lists a less expensive coil that is reportedly equally suitable for using with Dyna-S.
If it fails
- loudhvx
08 Feb 2011 08:22 - 08 Feb 2011 08:27
Patton wrote:
O yeah, there is also that option. If you go to the Dyna S, you can use the much cheaper 4-ohm Emgo coils. They are originally for points ignitions, but since the Dyna S dwell is so long, they work with the Dyna S too.
Used Ebay coils may just put you into the same boat you're in now. It's a gamble, but may be worth it if you get lucky and the coils are good. But I wouldn't travel very far from home on those coils. That link you gave is not worth a gamble, see my next post.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 08 Feb 2011 08:27 by loudhvx.
- loudhvx
08 Feb 2011 08:26
bigbeardan wrote:
I wouldn't bid. The 1980 KZ550 A had points and so those coils could be 4-ohm.
The 1980 KZ550 C should be 2.3-ohm, but he dosn't say which model they are from.
so we are agreed then that the one coil is trash? if i do go dyna s n future it will b a while. im just trying to keep my build as cheap as possible to have a good rideable bike, then upgrade as i go, but would really like to have something to ride, lol, and my goal for it is 1k end result...hardtail tank and all.
what bout these???
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...e=STRK%3AMEBIDX%3AIT
1981 KZ550 D1 gpz.
Other links.
Other links.
- bigbeardan
08 Feb 2011 08:39
guess i just need to come off the cash and get the dyna's, lol. i'm only bout $230 into is so far
- bigbeardan
- bigbeardan
14 Feb 2011 11:47
bigbeardan wrote:
dude im so ready for my parts to come in...........
its done.....ordered!!
- bigbeardan
15 Feb 2011 19:41 - 15 Feb 2011 19:44
bigbeardan wrote:
santa came to see me in his brown truck today!!
dude im so ready for my parts to come in........... :
Last edit: 15 Feb 2011 19:44 by bigbeardan.
- MFolks
15 Feb 2011 20:51
When I put the green 3 ohm coils on my bike, I used brush on Glyptol(Glyptal) to prevent the iron laminations from rusting. Most good electrical/electronic supply places sell it in a small bottle.
When installing your new coils, check for grounding problems as some bike's mounting hardware is close to the terminals.
The Dyna coils use a ring lug to provide the connections on the primary side. Try not to loose the 10-32 X 5/16" screws as others may bottom out before the terminals are tight.
I'd suggest using a lock washer and flat washer on the primary wires for vibration protection.
- bigbeardan
15 Feb 2011 21:31
MFolks wrote:
thanks for the tips...do u think a dab of loctite would work?
- MFolks
15 Feb 2011 22:14
As long as you're careful in using the Blue #242 Loctite(not the Red type as it needs about 350 F to loosen and by then wire insulation and the coils will be damaged).
A very small amount on the screws should provide vibration protection for the primary wires.
- bigbeardan
16 Feb 2011 18:50
great......new coils/wires/plugs and went from weak spark to none
regoin over it tryin to figure it out.....any 2cents welcome
16 Feb 2011 19:52
bigbeardan wrote:
What coils?
Which ignition?
great......new coils/wires/plugs and went from weak spark to noneregoin over it tryin to figure it out.....any 2cents welcome
What coils?
Which ignition?
