Coils?
Re: Coils?
08 Feb 2011 10:06
#429428
Bugeater wrote:
Thats funny - I was tearing down my new-to-me 75 z1b and found i have some blue andrews coils.. couldnt finy any google images cept the red n black ones. They have 6262A stamped on em and what looks like a date stamp of 2-81. Used with dyna s.. anyone know these, and resistance???
Am unfamiliar with the mentioned coils, but suspect they replaced the stock 3.2~4.2 ohm coils which worked with the stock points ignition which the Dyna-S replaced.
Would measure each coil's resistance between the primary terminals and look for a range of 3.2~4.2 ohms.
An inexpensive ohmmeter should work just fine.
While measuring, could reset ohmmeter to its highest range and also determine ohms between each coil's high tension (plug wire) terminals, to compare with the stock coil's 30,000± ohms.
Good Fortune! :)
  • Bugeater
  • Bugeater's Avatar
Re: Coils?
08 Feb 2011 11:34
#429445
Thanks guys... I am planning on switching to the Dyna 2000 and want to see if these will work with it and save some pennies not buying the Dyna 2000 DDK2-1 with coils.
75 Z1B Turbo...
1327cc Wiseco 10.25:1
Mr. Turbo (Mikuni 42mm HSR draw through setup)
Dyna 2000 controller with their miniature series 3ohm coils
74 Z1A 1105cc...
