Coils?
- Grinder
- Summerville SC long time KZ owner Short time membe
Coils?
04 Feb 2011 06:11 - 04 Feb 2011 06:14
The 1980 KZ1000B4 im working on has a yellow coil with andrews chicago imdossed on side bike runs fine just looking for info on the coils? i looked on the company web page didnt find any thing on the coils
Last edit: 04 Feb 2011 06:14 by Grinder.
Re: Coils?
04 Feb 2011 06:26
Grinder wrote:
May use ohmmeter to determine resistance between primary winding terminals, and compare to factory coil specs.
Andrews coils are comparable with Dyna coils in quality.
Both brands carry different coils to match resistance requirements of a particular application (such as whatever ignition is currently fitted to 1980 KZ1000B4 at hand.)
- steell
Re: Coils?
04 Feb 2011 09:21 - 04 Feb 2011 09:25
As far as I know Andrews specialises in strictly HD stuff now. The only non HD thing I can find is Polaris cams.
Take a look:
www.andrewsproducts.com/Subpages/information_downloads.htm
Accel coils are yellow and currently manufactured.
Andrews sells 4.8 ohm and 2.8 ohm coils for HD, long as the ohms work with your ignition and you can make them fit your bike, there's no reason you can't use them on a Kawasaki.
Take a look:
Last edit: 04 Feb 2011 09:25 by steell.
Re: Coils?
04 Feb 2011 12:37 - 04 Feb 2011 12:38
Thanks, steell!
Attack of dementia, tunnel vision and "yellow" caused instant spin off into Accel apoplexy. :laugh:
[Click on image to board bus.]
Last edit: 04 Feb 2011 12:38 by Patton.
- Grinder
Re: Coils?
04 Feb 2011 16:56 - 04 Feb 2011 17:08
the andrews coils r were on the KZ when i came to own it, and by the looks of them theve been on it a long time. very good spark. i talked with the techs at andrews they did produce the coils for a short while and they r 3.0 ohms .. guess ill keep them on the bike when it goes together
Last edit: 04 Feb 2011 17:08 by Grinder.
- steell
Re: Coils?
04 Feb 2011 21:24
No one was saying that Andrews didn't sell KZ coils in the past, they used to sell cams for the KZ motors also.
Andrews is just another of those companies that is still around but no longer dealing with Kawasaki motorcycles, RC Engineering being another one you see brought up once in a while.
And Yoshimura, plus a bunch of others I can't remember.
- Grinder
Re: Coils?
05 Feb 2011 06:24
sorry, didnt say or mean to imply that it was said andrews didnt make them, just letting every one know what i found.
thax to all that have imput or help!
- Grinder
Re: Coils?
05 Feb 2011 06:25
Didnt say i thought it was implyed that they didnt make them. was letting every one know what i found. there is always a lot of help here this forum is great!!!!!! and most here are out to help and guide people along with stuff!
thax to all that help, incourage, inspire, and bring the experance to others
thax
1979 teaching my wife to ride on a 1978 KZ650
thax
- steell
Re: Coils?
05 Feb 2011 08:16
It's all cool
On 30+ year old bikes it's hard to tell what you'll find, lots of things get changed and modified over the years.
- trianglelaguna
Re: Coils?
05 Feb 2011 08:23
thye cool thing is ...if they are working and dont give you any trouble...then you may not only have a decent ignition and coils match...but you may have an older pair that was from a good run/batch ..and they may/will last forever....no need buying newer ones and stepping down in quality or chance them being only "as good"...
i wish i had a set of those old yellow brands just because :woohoo: !!!!
that is cool too the guys gave you excellent answers ....
good luck...more pics around anywhere....
p.s i taught my then wife in 86 to ride on a sr650 with a 750 motor in it...on a playground on the weekend....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Bugeater
Re: Coils?
08 Feb 2011 09:27
Thats funny - I was tearing down my new-to-me 75 z1b and found i have some blue andrews coils.. couldnt finy any google images cept the red n black ones. They have 6262A stamped on em and what looks like a date stamp of 2-81. Used with dyna s.. anyone know these, and resistance???
75 Z1B Turbo...
1327cc Wiseco 10.25:1
Mr. Turbo (Mikuni 42mm HSR draw through setup)
Dyna 2000 controller with their miniature series 3ohm coils
74 Z1A 1105cc...
74 Z1A 1105cc...
- loudhvx
Re: Coils?
08 Feb 2011 10:03
A few people here were/are using the blue Andrews coils.
I think they were 3-ohms, but someone may need to confirm that.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
