Making turn signals from scratch
- loudhvx
Re: Making turn signals from scratch
27 Jan 2011 00:36
Great! Glad you got it figured out.
JonZweifel wrote:
If there are other symptoms, like idling rough etc. then you may want to look further into the voltage at the ignition switch (versus what's on the battery).
Glad it's working anyway.
JonZweifel wrote:
That's strange. The feed from the ignition switch should be nearly the same voltage as the direct feed. If it's dim, then that could indicate that the voltage on the ignition switch is low for some reason. It could be a bad connection somewhere or dirty contact on the fuses....it did work without the direct positive feed to the flasher but they were SO dim, hooked up the direct positive feed to the flasher and they were REALLY bright...
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Motor Head
27 Jan 2011 20:36
Would be a good Idea to take a moment and use the Diagram, Cut and Paste to say Paint, then draw what changes were made for the system to work, add the flasher part #, resistor value, etc. Then post that for the next guy, who hopefully will use the search function. :laugh:
Anyway glad you have signals, did I read only on the back?
- JonZweifel
07 Feb 2011 20:15
Sorry it took so long guys!
had to try about a hundred times to catch it with the light on lol.
I have a set of brackets ordered that i should be able to mount on in the same place and just glue the LED strip inside of but for now the zip ties will do.
In the pic of the on/off/on switch you can also see the flasher zip tied behind a bracket on the frame
Let me know what you think!
- JonZweifel
07 Feb 2011 20:17 - 07 Feb 2011 20:23
Sorry guys I was posting the pics wrong they are on the next page
Last edit: 07 Feb 2011 20:23 by JonZweifel. Reason: Wasnt posting pics right
- JonZweifel
- jjdwoodman
- Live free, or die.
07 Feb 2011 20:41
Very nice. Glad to see you got them working. So are you fully legal now?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
81 550 Mostly there
83 ZN1300 Voyager
- JonZweifel
