Anyone here own a MSD MC1 or MC2 ignition?
- otakar
Re: Anyone here own a MSD MC1 or MC2 ignition?
22 Oct 2010 20:05
If you are using an electronic ignition to trigger it. You need it with the amplifier. So a Dyna-s or Dyna-III or the stock Kawasaki ignition should fire it fine. You need to fire it with the wires going to the coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
23 Oct 2010 07:34
Why is it raining on a day i want to do this?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
23 Oct 2010 09:32
dejavoodo41 wrote:
I have made mine 100% plug-N-play with the harness I made. Just unplug the wires from the ignition coils plug four of the wires from the harness back to the coils and the other four wires from the harness to the four wires that were unplugged from the coils. Than just attach the remaining two wires from the box to the battery or to the fuse box.
When the Dyna III that came installed on my bike went out I tried to install the MCI that I was given when I bought my bike but it didn't have the OE connector and my bike is bare bones as far as wiring goes. I tried to get it to work and gave up trying to get the info and put in a Dyna S that I was also given with the bike. Maybe I'll have to give it another go.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
23 Oct 2010 09:33 - 23 Oct 2010 09:36
otakar wrote:
May have to implement Plan B. :woohoo: :laugh: :laugh:Why is it raining on a day i want to do this?![]()
Last edit: 23 Oct 2010 09:36 by Patton.
- otakar
23 Oct 2010 10:01
Patton wrote:
Yea, that would be Good Fortune. More than I could hope for. :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
29 Oct 2010 16:42
Did you get it tested and working?
- otakar
29 Oct 2010 19:44
Not yet, but I will have time tomorrow. I will post my results.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
07 Nov 2010 07:07
Just picked up another MSD MC-1 Ignition box a few days ago. This one had the wires cut between the box and the plug for some reason, but did come with the adapter harness. All of my speculations about the wiring system was confirmed. Considering that the replacement MC-3 for this box is $550 now, I think I got a good deal. I mounted the first box the other day, and the first thing I noticed was that the bike fired on the second tick-over in 28*f temperature. Where before it would take about 10 turns at that temp. Also I noticed that my "rich Condition" between 2k-3k is no longer noticeable during acceleration. I seam to have a LOT more power in some RPM bands, most likely where the bike is running rich. I think I will pick up and restore as many of these MC-1 and MC-2 units as I can find at a good deal. It will be interesting to see if my fuel efficiency goes up, which it should. I get 40.5MPG on the bike now with all the Hi performance mods I did and that is about 45/55- Highway/City riding. If I get more efficient burn, that should give me more power and better response. Therefore lower throttle settings while riding.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
08 Nov 2010 20:30
Cool. Are you going to play around with the plug gaps some more? You're running those Hot U's ND plugs, right?
Maybe go back to those forum posts at MSD and add your harness/ adapter wiring in a drawing for the guy's with questions still. That is if you haven't already.
That harness you made up looked real nice.
- otakar
09 Nov 2010 15:25
Yes I am running the ND (Denso) hot-U plugs but not the new exotic metal ones. Just the original copper core ones. I find that they are better for the bikes than the newer plugs. This new ignition is going to burn threw plugs I suspect, with the estimated 90-100kV spark. I am at a .060" (1.5mm) gap now and may go to .080" (2.0mm) gap. It starts to get hard to open the electrodes up that much. It's a bitch to open them up to 60-thou and keep the electrode centered and straight.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- loudhvx
10 Nov 2010 09:47
Glad you got it working. Sounds like you got a deal and then some.
The actual voltage at the plugs will be determined by the gap opening and how easily the air/fuel ionizes in the gap. By opening the gap, the current will be reduced, so that will actually reduce the wear on the plugs (compared to having smaller gap with the same ignition system).
The extra wear will come from having more current in the new system and having more sparks per revolution (at lower RPMs) than the stock system. But plug sacrifice is worth it if you're getting that much more power or smoother power.
What compression ratio is this motor?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- otakar
10 Nov 2010 14:48 - 10 Nov 2010 14:52
I'm at about 11:1 compression. Might a skoush higher. Plus I am still using the 2.2 Ohm coils. MSD recommends 1.5 Ohm and I am going to install 0.7 Ohm. They push the 1.5 Ohm because that is what they sell. I was told straight out by them "the lower the resistance the better".
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 Nov 2010 14:52 by otakar.
