Anyone here own a MSD MC1 or MC2 ignition?
  • otakar
  • otakar's Avatar Topic Author
Re: Anyone here own a MSD MC1 or MC2 ignition?
22 Oct 2010 18:45
#408354
Very much looking forward to mounting and testing this thing tomorrow.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • sm0kinace
  • sm0kinace's Avatar
22 Oct 2010 18:59
#408359
Good luck! hope ya don't blow a fuse...or fry a coil....
1978 KZ650
Ichyta, KS
  • otakar
22 Oct 2010 19:54
#408368
I have the right coils for it and because I have no standard bulbs anywhere on the bike (including headlight, which is only 2.8A HID) I am not worried about overtaxing the electrical system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • dejavoodo41
  • dejavoodo41's Avatar
22 Oct 2010 19:59
#408369
When the Dyna III that came installed on my bike went out I tried to install the MCI that I was given when I bought my bike but it didn't have the OE connector and my bike is bare bones as far as wiring goes. I tried to get it to work and gave up trying to get the info and put in a Dyna S that I was also given with the bike. Maybe I'll have to give it another go.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • otakar
22 Oct 2010 20:05
#408370
If you are using an electronic ignition to trigger it. You need it with the amplifier. So a Dyna-s or Dyna-III or the stock Kawasaki ignition should fire it fine. You need to fire it with the wires going to the coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
23 Oct 2010 07:34
#408445
Why is it raining on a day i want to do this? :( :angry:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
23 Oct 2010 09:32
#408460
I have made mine 100% plug-N-play with the harness I made. Just unplug the wires from the ignition coils plug four of the wires from the harness back to the coils and the other four wires from the harness to the four wires that were unplugged from the coils. Than just attach the remaining two wires from the box to the battery or to the fuse box.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
23 Oct 2010 09:33 - 23 Oct 2010 09:36
#408461
May have to implement Plan B. :woohoo: :laugh: :laugh:
Good Fortune! :)
Last edit: 23 Oct 2010 09:36 by Patton.
  • otakar
23 Oct 2010 10:01
#408464
Good Fortune! :)
Yea, that would be Good Fortune. More than I could hope for. :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Motor Head
  • Motor Head's Avatar
29 Oct 2010 16:42
#409823
Did you get it tested and working?
  • otakar
29 Oct 2010 19:44
#409845
Not yet, but I will have time tomorrow. I will post my results.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
07 Nov 2010 07:07
#411446
Just picked up another MSD MC-1 Ignition box a few days ago. This one had the wires cut between the box and the plug for some reason, but did come with the adapter harness. All of my speculations about the wiring system was confirmed. Considering that the replacement MC-3 for this box is $550 now, I think I got a good deal. I mounted the first box the other day, and the first thing I noticed was that the bike fired on the second tick-over in 28*f temperature. Where before it would take about 10 turns at that temp. Also I noticed that my "rich Condition" between 2k-3k is no longer noticeable during acceleration. I seam to have a LOT more power in some RPM bands, most likely where the bike is running rich. I think I will pick up and restore as many of these MC-1 and MC-2 units as I can find at a good deal. It will be interesting to see if my fuel efficiency goes up, which it should. I get 40.5MPG on the bike now with all the Hi performance mods I did and that is about 45/55- Highway/City riding. If I get more efficient burn, that should give me more power and better response. Therefore lower throttle settings while riding.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
