SPARK PLUGS BOSCH
- otakar
Re: SPARK PLUGS BOSCH
10 Oct 2010 15:19
One thing that I forgot to mention was to stay away from the fancy plugs like Platinum or Iridium. You would be paying a lot of money for absolutely no benefit. Stay with either Copper core or with Silver core and with full electrode with. Do not use any of the ones with the thin electrodes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
13 Oct 2010 07:06 - 13 Oct 2010 07:15
The Denso plugs that were the best plugs ever made for these bikes were the #4030 (W24ES-U) They give the best Life, Efficiency, Power, and all around general performance. They were more expensive than the NGK plug and therefore not used from the factory. However they were listed as the optional plug by Kawasaki. The NGK plug dose not come close to the Denso (ND) plug. This is the reason I made the investment and bought so many f them. There is NO SUBSTITUTE. They are by far the best. The only other plug that I have found that even comes close to the Denso "Hot-U" plugs are the German Made "Beru" "Silverstone" plugs, #S7. I just don't like to spend $9 per plug. Here is a link to a previous post we did about this.
kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=351334
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 13 Oct 2010 07:15 by otakar.
- loudhvx
13 Oct 2010 08:13 - 13 Oct 2010 08:15
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationLet the bidding begin!
Set of 3.
Set of 4. (Does not say "new", but shows boxes.)
One.
Set of 3.
One.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Oct 2010 08:15 by loudhvx.
- tachrev
- Rubber Side Goes Down
13 Oct 2010 11:33
Odd...I have use Bosch in cars with no issue. I usually use Autolite, though.
Only use NGK in my bikes.
I don't even like putting Champions in my lawnmower, had nothing but bad luck with them.
Build Thread
Build Thread
- otakar
13 Oct 2010 12:09
When I used to race back in the late 70s and early 80s we tested all kinds of plugs and the B8ES plugs were the first thing we threw away and replaced with ND (now Denso) plugs. As new and more modern stuff came out we tested that stuff, but always wound up back with the ND W24ES-u plugs. I used to have couple of friends that worked for BOSCH and I was able to get almost anything I wanted for FREE. Nothing survived. My neighbor who has a foreign car repair service, also refuses to use BOSCH components due to their poor track record. He told me he just cant afford to replace parts multiple times for free due to failure. That gos for ALL electrical components, such as Sensors, Plugs, Injectors and so on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kapahulu
17 Oct 2010 02:46
I googled and found a few sources for the w24es-u. Now you have me interested.
2strokeworld.com
2strokeworld.com
- otakar
17 Oct 2010 08:05
I used to live in Kaneohe and race at Industrial park.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kapahulu
18 Oct 2010 10:25
otakar wrote:
Let me know if you make a trip back to Hawaii!
Aloha, Mike
Campbell Industrial's race park closed a few years ago. H-3 was a good place to go fast for several years and then the cops started tagging people there.I used to live in Kaneohe and race at Industrial park.
Aloha, Mike
2strokeworld.com
2strokeworld.com
- Kapahulu
23 Oct 2010 20:08
I bought that set of Denso plugs on E-bay. Looking forward to trying them out.
2strokeworld.com
2strokeworld.com
- otakar
24 Oct 2010 10:12 - 24 Oct 2010 10:12
If you are running stock coils than gap them at .030-.035" If you are using aftermarket coils, such as Dyna, than gap them between .045"-.060" I run mine at .060" with Dyna gray 2.2 Ohm coils. Once I install the MSD box i will open them to .080". Use this link as a guide.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Oct 2010 10:12 by otakar.
- Kapahulu
24 Oct 2010 10:50
That brings up another question (coils). I am trying to figure out what works with my bike. It has a Dyna S ignition and stock coils. I believe the Dyna green coils will work with it, right?
And I have read about removing the resistor. Where is the resistor located?
Thanks
Thanks
2strokeworld.com
2strokeworld.com
24 Oct 2010 13:49 - 24 Oct 2010 13:50
Kapahulu wrote:
Here's the obscure pic from FSM, but shows general location, and the text notes colors of wires involved (i.e., red and pink).
[Click on image to enlarge view.]
...Dyna S ignition and stock coils. I believe the Dyna green coils will work with it...have read about removing the resistor. Where is the resistor located?....
Last edit: 24 Oct 2010 13:50 by Patton.
