SPARK PLUGS BOSCH
  • Hogslayer
  • Topic Author
  • PUFF DADDY
09 Oct 2010 08:34 #405454 by Hogslayer
SPARK PLUGS BOSCH was created by Hogslayer
Anyone ever tried Bosch spark plugs in a 900 or 1000 Kawi?
09 Oct 2010 08:45 #405455 by loudhvx
Replied by loudhvx on topic SPARK PLUGS BOSCH
I haven't tried them in KZ's, but the only plugs that have consistently failed on me, in several different cars, were Bosch. Some didn't even make it a few months, whereas the cheapest of the cheap champions, in the same vehicle lasted years and years. Lesson learned.
09 Oct 2010 09:39 #405465 by MFolks
Replied by MFolks on topic SPARK PLUGS BOSCH
I've had good luck using Denso W24ESU's. At one time I had a series of NGK plug failures that were real head scratchers, as the plugs would idle fine but would fail/act up under load.
Changing to Denso sparkplugs solved this problem.....
09 Oct 2010 19:20 #405580 by otakar
Replied by otakar on topic SPARK PLUGS BOSCH
Bosch are junk I also like the Denso plugs. I also like and use nothing but the w24es-u plugs. I run mine with a.060 gap with Dyna coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
09 Oct 2010 20:04 #405583 by 650ed
Replied by 650ed on topic SPARK PLUGS BOSCH
+1 on the Denso ES-U plugs.
10 Oct 2010 08:42 #405650 by fordtruck
Replied by fordtruck on topic SPARK PLUGS BOSCH
Where do you find Denso plugs? Can they be picked up at Autozone or O'reilly's?
'77 KZ1000-MTC 1075 kit. Stage 1 port
10 Oct 2010 09:39 #405657 by loudhvx
Yes, sometimes.
Denso used to be called NipponDenso or ND.
10 Oct 2010 10:18 #405667 by otakar
Actually
Those plugs are no longer available on the open market. I bought every one left in the US from Denso. They're $3.99 each
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Motor Head
10 Oct 2010 10:40 #405672 by Motor Head
Replied by Motor Head on topic SPARK PLUGS BOSCH
Go here to Rock Auto, thats where to get them cheap.
www.rockauto.com/catalog/raframecatalog.php
Price $1.33 + POST
DENSO Part # 4030 More Information About this Part {#W24ESU} Standard
Category: Spark Plug
10 Oct 2010 10:55 #405676 by otakar
Did you try to order any from them? Why don't you try and order four and see what happens.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
10 Oct 2010 12:52 #405698 by JR
Replied by JR on topic SPARK PLUGS BOSCH
NGK all the way.
Champion in a pinch.
Dont waste money on Bosch
10 Oct 2010 13:57 - 10 Oct 2010 13:59 #405722 by 650ed
Here's another place for plugs:
Club Plug
Last edit: 10 Oct 2010 13:59 by 650ed.
