SPARK PLUGS BOSCH
- Hogslayer
- PUFF DADDY
SPARK PLUGS BOSCH
09 Oct 2010 08:34
Anyone ever tried Bosch spark plugs in a 900 or 1000 Kawi?
- loudhvx
Re: SPARK PLUGS BOSCH
09 Oct 2010 08:45
I haven't tried them in KZ's, but the only plugs that have consistently failed on me, in several different cars, were Bosch. Some didn't even make it a few months, whereas the cheapest of the cheap champions, in the same vehicle lasted years and years. Lesson learned.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- MFolks
09 Oct 2010 09:39
I've had good luck using Denso W24ESU's. At one time I had a series of NGK plug failures that were real head scratchers, as the plugs would idle fine but would fail/act up under load.
Changing to Denso sparkplugs solved this problem.....
- otakar
09 Oct 2010 19:20
Bosch are junk I also like the Denso plugs. I also like and use nothing but the w24es-u plugs. I run mine with a.060 gap with Dyna coils.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
09 Oct 2010 20:04
+1 on the Denso ES-U plugs.
- fordtruck
10 Oct 2010 08:42
Where do you find Denso plugs? Can they be picked up at Autozone or O'reilly's?
'77 KZ1000-MTC 1075 kit. Stage 1 port
- loudhvx
10 Oct 2010 09:39
fordtruck wrote:
Yes, sometimes.
Denso used to be called NipponDenso or ND.
Yes, sometimes.
1981 KZ550 D1 gpz.
Other links.
Other links.
- otakar
10 Oct 2010 10:18
Actually
Those plugs are no longer available on the open market. I bought every one left in the US from Denso. They're $3.99 each
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
10 Oct 2010 10:40
Go here to Rock Auto, thats where to get them cheap.
www.rockauto.com/catalog/raframecatalog.php
Price $1.33 + POST
DENSO Part # 4030 More Information About this Part {#W24ESU} Standard
Category: Spark Plug
Price $1.33 + POST
- otakar
10 Oct 2010 10:55
Did you try to order any from them? Why don't you try and order four and see what happens.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JR
10 Oct 2010 12:52
NGK all the way.
Champion in a pinch.
Dont waste money on Bosch
10 Oct 2010 13:57 - 10 Oct 2010 13:59
Last edit: 10 Oct 2010 13:59 by 650ed.
