Starter button?
- KZ1100 Bully
It there a way to trouble shoot the key ignition and starter button? Is there a way to bypass the starter button?
Thanks
1983 Kawasaki KZ1100 Spectre D2
- MFolks
- Thank you received: 540
The next place to inspect would be inside the headlight housing as a majority of the bike's electrical connectors mate with the ones from the main harness.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the “On†position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Stumped as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some “De-oxit†from Radio Shack Stores or any good electronic supply store. www.deoxit.com is their website.
- Motor Head
- Thank you received: 391
- MFolks
- Old Man Rock
- Thank you received: 225
If so, check solenoid/starter terminals... Clean, non oxidized, good ground etc....
Just a thought....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- KZ1100 Bully
Not sure what to do now to get it to start. It will start if I jump the solenoid.
I checked the clutch lock out and that was not it.
- hocbj23
- Visitor
- MFolks
Look at the Negative(-)terminal connection going to the engine mounting bolt too, as this gets overlooked when troubleshooting.
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- hocbj23
- Visitor
Rock:Where have u been? Been missing ur insightful posts.bjJust out of curiosity,,, DVM voltage measurement at starter switch to starter solenoid... +12Vdc(+) getting switched?
Just a thought....
- KZ1100 Bully
Since my bike still starts by wiggling the button, I haven't performed this repair, but will keep you updated if I do the fix.
grant.
That seems about the same way mine started out a few months ago. Now nothing, I took it all a part and tried making a connection. There is power going to the wires in the button, even the black wire has power
Sure wish there was a way to bypass.
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
Oh, and De-oxit. What kind of chemicals are in it?? I've tried using carb cleaner and brake cleaner. They clean the brass parts up but as it turns out they gellify and lock together the plastic terminals.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
