Starter button?
- KZ1100 Bully
Starter button?
18 Sep 2010 14:26 - 18 Sep 2010 14:26
Hi, my bike does not start anymore. At Times before I would have to wiggle the key or the starter button to get it to start. It rained pretty hard the other day and the next day when I went to start it it would not start. I turn the key the lights come on I press the button and it does nothing. I can jump the solenoid and it will start.
It there a way to trouble shoot the key ignition and starter button? Is there a way to bypass the starter button?
Thanks
Thanks
1983 Kawasaki KZ1100 Spectre D2
Last edit: 18 Sep 2010 14:26 by KZ1100 Bully.
- MFolks
Re: Starter button?
18 Sep 2010 15:12
I'd open up the right handlebar switch pod looking for corrosion or broken wires. The run/stop and start switches are there.
The next place to inspect would be inside the headlight housing as a majority of the bike's electrical connectors mate with the ones from the main harness.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the “On†position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Stumped as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some “De-oxit†from Radio Shack Stores or any good electronic supply store. www.deoxit.com is their website.
- Motor Head
Re: Starter button?
18 Sep 2010 15:14
The Switch at the clutch lock out can cause this also, at clutch lever. Aren't there some bikes with a side stand switch as well?
- MFolks
Re: Starter button?
18 Sep 2010 15:23
I believe on his bike and like mine, the side stand switch turns on a flashing light as a warning. It's not until some time later Kawasaki created the interlocking switches that require a certain procedure to start the bike and then be able to ride away.
- Old Man Rock
Re: Starter button?
18 Sep 2010 17:02
Just out of curiosity,,, DVM voltage measurement at starter switch to starter solenoid... +12Vdc(+) getting switched?
If so, check solenoid/starter terminals... Clean, non oxidized, good ground etc....
Just a thought....
Just a thought....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KZ1100 Bully
Re: Starter button?
06 Dec 2010 06:46 - 06 Dec 2010 08:39
Help. I switched out the key ignition with a new one no luck. I switched out the solenoid and nothing. The handle bar run switch looks okay inside. When I press the button nothing happens, when I turn the switch to off I can hear a click in the solenoid.
Not sure what to do now to get it to start. It will start if I jump the solenoid.
I checked the clutch lock out and that was not it.
Last edit: 06 Dec 2010 08:39 by KZ1100 Bully.
- hocbj23
Re: Starter button?
06 Dec 2010 09:43
According to shop manual possibilities are:clutch lever not pulled,starter motor damaged,battery voltage low,relay not operating,starter button not contacting,wiring open or shorted,ignition switch damaged,engine stop switch damaged,engine stop switch in "OFF" position,fuse blown,starter lock out switch damaged.Good luck.bj
- MFolks
Re: Starter button?
06 Dec 2010 10:37
I'd check all the battery connections as they need to be clean and tight for maximum current flow. Also the one going to the starter motor.
Look at the Negative(-)terminal connection going to the engine mounting bolt too, as this gets overlooked when troubleshooting.
- Grantl
- KZRider is Da Bomb!!!
Re: Starter button?
06 Dec 2010 13:12
I've been having the same problem with my starter button. I took apart the right hand switch cover to find a spring-loaded (looks like a brass) pin. The pin looks like it gets worn out in the middle of the pin over time and (being too short) will not make the required contact. My proposed plan to fix this condition is to remove the pin from the small housing and either turn another one on the lathe or quick-fix the existing one by dropping some solder onto each end of the pin (to make it slightly longer.) Since my bike still starts by wiggling the button, I haven't performed this repair, but will keep you updated if I do the fix.
grant.
grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- hocbj23
Re: Starter button?
06 Dec 2010 13:39
Old Man Rock wrote:
Rock:Where have u been? Been missing ur insightful posts.bjJust out of curiosity,,, DVM voltage measurement at starter switch to starter solenoid... +12Vdc(+) getting switched?
Just a thought....
- KZ1100 Bully
Re: Starter button?
06 Dec 2010 15:37 - 06 Dec 2010 16:00
Grantl wrote:
That seems about the same way mine started out a few months ago. Now nothing, I took it all a part and tried making a connection. There is power going to the wires in the button, even the black wire has power
Sure wish there was a way to bypass.
grant.
Last edit: 06 Dec 2010 16:00 by KZ1100 Bully.
- Becker
- The Doctor Will Rise Again
Re: Starter button?
07 Dec 2010 01:15 - 07 Dec 2010 01:17
Just to clarify, the bike starts if you short the two terminals of the starter solenoid?? As in the screwdriver across the 10mm starter solenoid nuts method. Like, it cranks over then starts up and runs??
Oh, and De-oxit. What kind of chemicals are in it?? I've tried using carb cleaner and brake cleaner. They clean the brass parts up but as it turns out they gellify and lock together the plastic terminals.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Last edit: 07 Dec 2010 01:17 by Becker. Reason: spelling
