bullet to the head
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
bullet to the head
16 Sep 2010 16:15 - 16 Sep 2010 17:50
#399153
well i gave my bike power and what i thought was the right wiring. the guy who had the bike labeled half the wires. i had no lights or anything when i pushed the start button. now i have to go through all the wiring on the bike.
1978 KZ1000A2
Last edit: 16 Sep 2010 17:50 by kz1k.
Re: bullet to the head
16 Sep 2010 16:45 - 16 Sep 2010 16:48
#399160
:unsure: Does bike have a working kick starter?
Good Fortune! :)
Last edit: 16 Sep 2010 16:48 by Patton.
  • trianglelaguna
  • trianglelaguna's Avatar
16 Sep 2010 16:49
#399161
breath...it will all work out...even running perfect these 35 yr old kawasakis can do little tricks and quirks that just take time to learn....somthing small can have me thinking my bike blew up more than once...you have been staying at it....you have have been asking the right questions and getting feedback...you have a bit of a project ahead and your this far in...it will work out.....Craig...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • kz1k
16 Sep 2010 16:57
#399162
Good Fortune! :)
YES THE KICK START WORKS!!! all the lights and crap i could care less about. i just need to know if the motor runs to see if its worth my time and $ to fix up. is there a basic diagram to just get the motor going?
1978 KZ1000A2
16 Sep 2010 17:05 - 16 Sep 2010 17:08
#399166
Good Fortune! :)
For engine to run, need good fully charged battery and batt+ voltage to both coil primaries (usually furnished with ignition switch ON).
If necessary, may circumvent otherwise defective wiring by connecting a hot wire from batt+ terminal to coil primaries. (Disconnect while engine isn't running).
Assure good ground connection where battery negative cable attaches to rear of engine. And that both battery terminal connections are clean and snug.
Then use kick starter. Full choke, and NO throttle.
Would also remove plugs and visually observe spark while performing otherwise normal cranking procedure. Look for fat blue spark. Not thin orange spark.
With batt+ to coil primaries, and no spark at plug tips, suspect issues with coil or between coil and plug tips.
Good Fortune! :)
Last edit: 16 Sep 2010 17:08 by Patton.
  • trianglelaguna
16 Sep 2010 17:10
#399168
turn on the key...take a spare plug or pull a plug ..have a friend(not one you like)carefully hold the or rest the rubber boot agianst a head nut and kcik the bike over in a dark garage....
if it has spark....check if it is getting gas..and then post the progress....if it does not have spark...there is a check from the charged battery through the fuse box and through the ignition key and handle bar contolrs where they meet in the headlight bucket...there is a white wire under the side covers at the junction box...check that it is wiggled togehter good...check the fuses....
hope this helps some...others will chime in...
power...sparkles...gassy.....pop....oomph.....checked in that order imo
1976 KZ900
2003 ZX12R
2007 FZ1000
  • kz1k
16 Sep 2010 17:24
#399172
does it matter i have the electronic ingition?
1978 KZ1000A2
  • testarossa
  • testarossa's Avatar
16 Sep 2010 17:29
#399174
Click the link: kzrider.com/index.php?option=com_docman&...w&gid=113&Itemid=108
Scroll down to the bottom of the page and click the hotlink to the wiring diagram pdf.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • trianglelaguna
16 Sep 2010 17:35
#399177
kz1k wrote:
does it matter i have the electronic ignition?
is like asking if it matters if a girl has big boobs...
it matters...but not in this exact situation...:)
not really the bike if juiced up at the battery will kick over and show spark......of that is if it is a good spark plug...little stuff as you go in the beginning is frustrating becuase it comes at you all at once....some bikes have a wire to the kicktsand and to the clutch...and wont spark with the stand down or clutch out...mostly newer models ,but,some owners(the kind who install boots upside down ) will mix and match parts at will....
i bet you just got a wire not connected on the controls or a ground wire to the motor or a wire in the head light or sidecover not connected....
1976 KZ900
2003 ZX12R
2007 FZ1000
  • kz1k
16 Sep 2010 17:39
#399178
allright. thanks for the help guys. its time to get down to the nitty gritty. i was praying i wouldnt have to mess with the wires, but such is life....Joe
1978 KZ1000A2
  • testarossa
16 Sep 2010 17:43
#399181
:laugh: :woohoo: :laugh: :woohoo:
2004 ZX-10R
Angola, IN
  • kz1k
16 Sep 2010 18:03
#399193
1978 KZ1000A2
