Bike stalls when hot
  • Topper
  • Topper's Avatar Topic Author
26 Aug 2010 17:33
#394052
My '88 KZ305 is stalling out on me. It runs pretty good when it is cold, but after about a half hour of riding it starts to chug, chug, chug, then looses power and just dies.
If I let it sit for a minute it starts back up and I'm on my way. Sometimes for a mile or two, sometimes longer, then it dies again.
Once it gets warm, like after a day of running short errands it starts to stall out a lot. I can't go but a couple miles then it dies. Have to sit and wait and then I can go again.
My first guess was some gunk in the tank or something with the carbs, but now that it is clearly related to how warmed up the bike is, I'm not so sure.
Someone suggested the ignition coils. Does that seem likely? If so, how do I test them?
I've got a multimeter, but no shop manual for the bike.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Kawickrice
  • Kawickrice's Avatar
Re: Bike stalls when hot
26 Aug 2010 17:58
#394067
Is your gas tank vent clogged by chance, try loosening the gas cap and see if she does better. If that doesn't work I would look at the carbs and a dirty tank.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • PLUMMEN
  • PLUMMEN's Avatar
26 Aug 2010 18:09
#394072
could be many things,check coils for cracks.could also be vapor locking.....................
  • Saki Jockey
  • Saki Jockey's Avatar
26 Aug 2010 18:38
#394082
Ignition shutdown due to insulation loss (heat) is plausible. Carry a spare spark plug with you, pop the lead off the engine's spark plug, plug in your spare to the lead and ground the plug to the engine block. Try cranking and see if you have spark when the issue occurs...
Rob A.
550 A4
GTA,
Ontario, Canada
26 Aug 2010 18:39
#394083
Would check valve clearances.
Good Fortune! :)
  • Topper
27 Aug 2010 06:27
#394163
Where exactly is the vent located? The tank has been repainted, so it is entirely possible that they vent got painted over.
1979 KZ750 Twin
  • Motor Head
  • Motor Head's Avatar
27 Aug 2010 06:29
#394165
Its in the cap, try riding with the cap open, but not a full tank as it will tend to slosh. 1/2 tank or less maybe.
27 Aug 2010 07:04
#394175
If condition is due to fuel starvation resulting from vent blockage or flow obstruction, it's likely while riding that the float bowls are emptying faster than they are filling.
The bowl empties and the bike stops due to lack of fuel.
While stopped, the bowls s-l-o-w-l-y fill again, and the bike runs until the bowl empties.
Ditto, ditto, ditto . . . .
Good Fortune! :)
  • Kawickrice
27 Aug 2010 07:35
#394199
If you look real close on the bottom of the cap you should see a very small hole which vents the tank to the outside atmosphere. Make sure it is unobstructed. If this gets clogged it will do exactly as Patton said. That is the cheapest and simplest fix so lets hope that is the culprit
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Topper
27 Aug 2010 11:23
#394265
Ok, I'll check the gas cap when I get home. Would that get worse as the bike warms up?
1979 KZ750 Twin
27 Aug 2010 12:04
#394272
Not necessarily.
But too tight valve clearances get worse as the bike warms up.
Good Fortune! :)
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
27 Aug 2010 14:14
#394327
Once the bike is hot (and starts goofing), perform a compression test. Turn off gas, drain float bowls. Remove all plugs. Connect compression tester, and crank engine while holding throttle wide open.
Numbers should not be more than 10% difference, and all should be over 120psi hot.
Checking valve gap is considered a part of regular maintenence in the manual for these bikes, so if you havn't in a long time, your problem could just be neglect, and a simple shim swap could solve your problem.
Taking extra plug and connecting it to lead, then holding against head while cranking is good advise to check spark.
Gap the plug to about 1/8th inch, as it will make the spark easier to see, and coils should be able to jump this gap in atmospheric pressure, no problem. Spark should be snapping and whitish/blue, without missing at all (constant spark!).
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
