No spark
- mpduda509
No spark
21 Aug 2010 16:53
My 1978 Kawasaki KZ650Sr Still has no spark just replaced the key switch and made huge progress but it is still not getting spark i pulled the points cover off and inspected the points they seem to be ok the bike has 9000 miles what could be the problem?
- Motor Head
Re: No spark
21 Aug 2010 17:09
Got any power at the coils? Do you have a test light or DVOM?
Re: No spark
21 Aug 2010 19:52 - 21 Aug 2010 19:55
With ignition switch ON, can measure voltage at the dual connector supplying both coils. (See image below.)
The wire might be solid red instead of red/yellow.
How does this voltage compare to voltage measured across the battery terminals?
Last edit: 21 Aug 2010 19:55 by Patton.
- darling741
Re: No spark
24 Sep 2010 10:07
The spark plug caps at the end of the plug wires can go bad. I had spark on only one cylinder when I bought my 79 SR and found that three of the plug caps were bad.
- JR
Re: No spark
24 Sep 2010 13:30 - 24 Sep 2010 13:31
Once upon a time I had a dead bug smeared across the contacts on the kill switch. No spark on any cyclinders.
I would suggest that you need to get a multimeter and trace back from the coils to find where you have voltage
You could also rig up a simple test light with a 12V bulb and some wire instead of a multimeter
Last edit: 24 Sep 2010 13:31 by JR.
