73 Z1 timing set
  • stonemaster
  • stonemaster's Avatar Topic Author
73 Z1 timing set
18 Aug 2010 04:05
#391834
I have set timing somewhat close using a ohm meter, separately on each set of points, my ? is ...with the timing light do you time off the 1 &4 cylinders only or do you do 2&3 as well separately ???
thanx
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: 73 Z1 timing set
18 Aug 2010 06:47
#391853
Set the timing for 1-4 first by lining up the F mark with the case mark, then do the 2-3 side the same, seperately.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Kawickrice
  • Kawickrice's Avatar
18 Aug 2010 09:23
#391893
If your static timing is dead on chances are the light will be to. At least in my expierence any ways. Sounds like you are close to getting her going.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • stonemaster
18 Aug 2010 16:01
#391958
oh she's running and not too bad, jus dialing it in, thanx for the help, the factory manual is a little fuzzy on the timing IMO and I'm used to timing an ironhead anyway. Me thinks I need to file my point as well.
18 Aug 2010 16:24
#391964
Each set of points is separately adjusted for gap.
Each set of points is separately adjusted for timing.
Set gaps first, before setting timing.
Good Fortune! :)
18 Aug 2010 16:31
#391966
When contacts need cleaning, a strip of fine sandpaper, folded over to expose sand on both sides, is handy to pull through the contacts on closed points.
If desired, may use your finger to add a little pressure toward holding the contacts more firmly together while pulling the sandpaper through.
May work as well or better than a point file.
Good Fortune! :)
  • stonemaster
18 Aug 2010 16:53
#391974
that is a good one, thanx alot man me thinks you just saved me some time
  • stonemaster
18 Aug 2010 16:58
#391975
Good Fortune! :)
are you saying if the point face is not flat then I should replace???
18 Aug 2010 17:28
#391981
stonemaster wrote:
...are you saying if the point face is not flat then I should replace???
Cleaning the contact interface by filing or sand papering should help remove any pitting and also improve the contact area, which should be flat to flat as much as possible.
Good Fortune! :)
  • Kawickrice
18 Aug 2010 17:44
#391985
Good Fortune! :)
I have used match books in a pinch on the side of the road before.
If the points will not line up I would replace them. But if they are dirty and square up, file em a little with Pattons method
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • stonemaster
18 Aug 2010 19:34
#392013
just double checked and they're not too bad , timing a little off and need to sync carbs, but i should have er nailed tomorrow,
