Ignition problem
- tmstoltz
Ignition problem
17 Aug 2010 22:29
I have a 1999 kz1000p It use to fire right away, but now when i try to start it it will turn over for a while then it will start popping and eventualy start. if i put it in the sun then it starts easyer i replaced the coils and pick up coils but the problem is still there should i replace the ic unit? but just before this problem my turn signals stopped working. and when i pulled the tank off i found the wires from the right handle bar controls were pulled tight acrossed the top of the engine, on the controles is the start button, sirene switch, headlight switch,and pursute switch. the turn sig. are on the left.any ideas what to do to get my bike working again?
- TeK9iNe
- What did you do!?!
Re: Ignition problem
18 Aug 2010 06:52
Check the wires to the coils and make sure you are getting close to battery voltage across both input wires of coils.
How old is the battery?
Have you checked the charging system?
Take some time to go thru your wiring and clean/repair any loos/corroded connectors, especially in the engine area and behind the headlight.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- sparkn
18 Aug 2010 07:12
I wouldn't eliminate fuel delivery if the bike runs fine after it does finally start. Does the bike start up OK if the petcock gets moved to the PRI position for a few seconds before starting? Is the choke functional? Unless, of course, that bike has fuel injection.
Does the siren still work? I'd get in so much trouble if I had a police bike.
1979 KZ650 SR
18 Aug 2010 10:10
Were spark plug wires also replaced?
If old and hard, may be leaking voltage, especially when damp.
Could remove plugs and observe spark quality while spinning the engine over.
Look for fat blue. Not thin orange.
18 Aug 2010 10:19
tmstoltz wrote:
Any particular reason why the pick up coils were replaced?
Were brand new ignition coils fitted, with correct ohm resistance?
I have a 1999 kz1000p It use to fire right away, but now when i try to start it it will turn over for a while then it will start popping and eventually start. if i put it in the sun then it starts easier i replaced the coils and pick up coils but the problem is still there should i replace the ic unit? but just before this problem my turn signals stopped working. and when i pulled the tank off i found the wires from the right handle bar controls were pulled tight across the top of the engine, on the controls is the start button, siren switch, headlight switch,and pursuit switch. the turn signals are on the left. Any ideas what to do to get my bike working again?
- tmstoltz
18 Aug 2010 20:50
it sounds like an ignition prob. and the coils are new the only parts left are the pick up coils(130.00) and the ic ignighter(390.00) althow i found an aftermarket for 95.00 (ricks motorsports)i hate to think im just throwing parts at a problem, the bike is 11 years old prob.needs these parts anyway.
- tmstoltz
18 Aug 2010 20:58
the batt. is two years old i keep it on a batt. tender i replaced the staror and the reg/rectifier with a oem the sataor is from ricks motorsports bike charges cruzeing 4500 rpms @ 13.9 volts. i will check all the connections again i might have missed one someware. thank you.
- tmstoltz
18 Aug 2010 21:01
the fuel system seems fine all works well its the electricle that stumps me an auto painter trying to be a bike mechanic thats the first problem.
18 Aug 2010 21:20
What's the observed spark quality?
- MFolks
18 Aug 2010 21:23
This forum has very skilled members, don't feel bad if the question you've asked seems odd or out of place.We all started out as "Newbies" one day.
- tmstoltz
- Old Man Rock
21 Aug 2010 14:55
Whoa... Orange Spark???? :blink:
You mentioned coil swap out but what about plug wires/caps?
Good ground to engine case?
Unfortunately, don;t have a Police special OEM manual regarding the electronics/ignitier module....
Loudvhx, you out there?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
