1974 Z1 900
- Grapes5x
1974 Z1 900
16 Aug 2010 09:58
Hello,
I need some help, I am not getting any spark. I have a Dyna III and new coils, Bike turns over and ligts are working, but now spark. Any ideas???:woohoo:
- TeK9iNe
- What did you do!?!
Re: 1974 Z1 900
16 Aug 2010 10:13
Check the coils with ignition on: are they recieving battery voltage?
Plugs and wires new?
Points clean/good, and gap/dwell , timing set correctly?
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- stonemaster
- MFolks
Re: 1974 Z1 900
16 Aug 2010 12:47
If no voltage at the ignition coils,check at the run/stop switch and start switch on the right handlebar switch pod.
If still nothing, open up the headlight housing and check for corrosion in the connectors or broken wiring.
Fuses look good? tight in their clips? no corrosion?
Battery connections clean and tight?
- Old Man Rock
Re: 1974 Z1 900
16 Aug 2010 16:47
"I have a Dyna III and new coils, "....
Assumption is pre Dyna, the engine ran correct?
Is switched +12Vdc getting to the ignition plate and through to the coils?
Static alignments performed on the Dyna?
Engine case proper grounded battery (-)?
As already mentioned, Dyna wired correctly?
Time to get out the volt meter....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
Re: 1974 Z1 900
16 Aug 2010 17:44
hmmm.....hahahaha
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Old Man Rock
Re: 1974 Z1 900
17 Aug 2010 05:46
Another thing, coil mounting... Are you sure you don't have the +12Vdc grounded/partially grounded to the frame?
Maybe these will help out....
Dyna Coil Installation:
kzrider.com/index.php?option=com_docman&...d&gid=469&Itemid=108
Dyna Ignition Plate Installation & adjustment:
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Grapes5x
Re: 1974 Z1 900
17 Aug 2010 18:36
Ok update, I am reading 14.02 voltes at the coils. Could it be a bad Dyna III?
- Old Man Rock
Re: 1974 Z1 900
17 Aug 2010 19:14
Possibly...
Did you accomplish the static test? If it lights up pending crank rotation then most likely not the Dyna.
Engine frame ideally grounded?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Grapes5x
Re: 1974 Z1 900
18 Aug 2010 15:36
Hey Old Man Rock,
First let me say thanks for all your help.
I checked the grounds and they are good. Let me tell you what happened, I was leaving for work one morning and she just died on me. I have all light working, 14.35 volts at the coils. 3.001 ohm of resistance at the coils. Did test from docs, still no spark!!!! Should I get a Dyan S or a Dyna 4?
Re: 1974 Z1 900
18 Aug 2010 16:15
Dyna III is powered by splicing into a bike's harness wire providing switched battery voltage.
Such splice may have failed, whereby the Dyna III won't function.
- Grapes5x
