1974 Z1 900
  • Old Man Rock
  • Old Man Rock's Avatar
Re: 1974 Z1 900
20 Aug 2010 14:59
#392551
May be missing in your reply but as can be reviewed in the attached image....
As Patton mentioned, you have a splice off the switched +12Vdc feeding power into the ignition plate, red conductor... The splice block from the Dyna has caused others issues versus splicing and soldering the junction....
Defineitely verify +12Vdc or higher is at the ignition plate feed into the pickups.
Also, infollowing the static alignemnt tests, not sure you answered this or I just didn;t understand but in doing so, if your auto light is turning on & off accodringly on the green or balck conductor feeds into the coil then the Dyna ignition is not your problem...
In other words, as your rotating the magnet rotor via the crank rotations to 1/4 & 2/3 TDC..... No light/DVM +12Vdc then either no +12Vdc to the ignition plate or both pickups are shot...
Is it possible both sensors are shot, sure but my gut feeling is as Patton brought up, missing +12Vdc to the plate... One pick shot, sure can happen but both simulataneously... hmmmm, me wonder.....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Grapes5x
  • Grapes5x's Avatar Topic Author
Re: 1974 Z1 900
20 Aug 2010 15:14
#392553
Thanks again "Old Man Rock" Just went out and retested, and now she doesn't even crank. Also she does not is Tick, test battery and it reads 10.21 volts. Placed back on tender, waiting for battery to recharge. Again thanks for the help.
  • Grapes5x
Re: 1974 Z1 900
20 Aug 2010 15:15
#392554
Oh and your pick is of the Dyna S, I have a Dyna III.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
20 Aug 2010 15:29 - 13 Feb 2012 19:40
#392556
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 19:40 by KZ250LTD.
  • Grapes5x
Re: 1974 Z1 900
22 Aug 2010 19:03
#393095
Could a bad battery cause the problems I am having?
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: 1974 Z1 900
22 Aug 2010 19:19 - 22 Aug 2010 19:23
#393100
... yes, unfortunately. All testing requires known good battery, new is best.
I like to use a car batt while testing, but some individuals seem to think that is an issue...
which it isn't. ;)
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 22 Aug 2010 19:23 by TeK9iNe.
  • stonemaster
  • stonemaster's Avatar
Re: 1974 Z1 900
22 Aug 2010 19:36
#393106
which it isn't. ;)
GL.
B)
as long as it isnt attached to a running car/truck battery it isnt an issue...
