- Thank you received: 391
Brown Wire Voltage on 3 Phase Reg/ Rectifier
- Motor Head
12 Aug 2010 13:13 #390375
by Motor Head
Brown Wire Voltage on 3 Phase Reg/ Rectifier was created by Motor Head
Can some of you guys who have 1 or maybe more of these Bikes with the electric Speedo/ Tach/ Odometer 3 phase charging system do a voltage measurement and post it here please.
I am looking to do some comparing.
I need Battery Voltage across the battery posts, with Key ON, and that means your head light should be on. Then Voltage across the brown, ignition switched wire, with key still ON. If you have the Left side panel off you will see the top right connector, this will be for your R/R, this would be where I would like the reading. Key On Engine Off.
Then If you could do it again with The Engine at Idle Speed.
I believe there may be several bikes out there with a slight overcharge situation, and would like to find out if I'm right. I get almost a full volt difference at the two points, even with manipulating the feed into the circuitry, past the Ignition switch, etc.
I'll thank in advance anyone who goes to the trouble, and if I find or you find the correcting solution we can share with KZR.
- MFolks
- Thank you received: 540
12 Aug 2010 14:20 #390389
by MFolks
Replied by MFolks on topic Brown Wire Voltage on 3 Phase Reg/ Rectifier
I believe the brown wire from the reg/rect is the sense circuit controlling the charge voltage.
www.wgcarbs.com has mentioned a good voltage source to tap would be the running light circuit.
On most Kawasaki's the rear lighting is:
RED,running light,or tail light.
BLUE(sometimes with a RED stripe), the brake light circuit.
BLACK with YELLOW stripe, the ground circuit.
Some bike's have front running lights with a dual filiment socket and bulb, they are usually using a BLUE wire for this circuit.
- loudhvx
- Thank you received: 1616
12 Aug 2010 14:36 #390394
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Brown Wire Voltage on 3 Phase Reg/ Rectifier
My wiring is all custom on my bikes. But the concept is the same. I still go reg/rec output to battery, then battery to main fuse, then mainfuse to main switch, then brown wire feeds off main switch back to the reg/rec. The more current going through the fuse, the more drop there will be (same goes for all wires and connections. The last time I checked I had about 3/4 volt drop, but that was while running. When I get a chance, maybe today, I'll do a quick check with lights off, not running, and lights on not running.
The measurement will be more accurate with the bike not running because there won't be any ripple in the voltage then, and it will be pure DC measurements. But If we are trying to see what the actual drop is, while running, I think it needs to be running.
To get a very accurate measurement of the voltage drop on the brown wire while running, the measurement should be done from battery positive terminal to brown wire on the reg/rec. That will directly tell you what the actual drop is. (Rather than doing a subtraction... ala measuring battery voltage and measuring brwon wire to ground, and subtracting the difference.)
Also, let's not forget the ground can also have drops the same way as on the brown wire, but it has fewer spots to worry about. So another good check would be to measure voltage from ground wire on the reg/rec to the negative post of the battery. Hopefully that is right about zero volts.
1981 KZ550 D1 gpz.
Other links.
- Motor Head
12 Aug 2010 14:49 #390399
by Motor Head
Replied by Motor Head on topic Brown Wire Voltage on 3 Phase Reg/ Rectifier
Thanks, I can reroute the Brown that just goes into the R/R sure, but was trying to find out if on these particular models if it is a common problem. Also what some readings are.
As it seems that as the brown is supplied from the ignition switch, white/ black wire, which is supplied from the main fuse, which of course is from a red/ white at the Y bullet connector to the battery/ R/R. So the brown is powered at 3 fuse rail in the Fuse panel, from there it does even more. It ends up when as brown, with the splices, running most of the bike, then with the other circuits on the After Fuse panel side, a lot of the rest of it. It ends up going back to the Ign switch where it it turns to red/ yellow for the coil/ ignitor circuit. Even supplying a fresh 12v source to the white/ black, after the Ign switch, and to the brown at the fuse panel end, did not increase the voltage on the brown at the R/R. The brown seems to stay nearly 1 volt lower than Battery voltage, which of course the R/R sees and makes up this difference to charge the battery. So if Brown is 14v, then R/R output red/ white is 15v.
So once the R/R thinks the Battery is low, do to the voltage on the brown, (sense) wire, up the charge voltage goes, enough to boil a battery on a long ride, especially in hot weather.
So I am thinking of where the problem is occurring, and that maybe this has also led to some of the "Coil Mod's) out there. As since the brown powers the Ignition system, voltage is down here as well.
- Motor Head
12 Aug 2010 15:03 #390402
by Motor Head
Yea did the ground check, this tested OK. These with all the load, electric gauges/ etc have a bigger demand on the system. So I was pondering that maybe the old wiring harness is not quite up to it any more, as it has "Step Down" in the harness. It comes off the fuse panel at one size, then drops in size around the bike. I will say 14 gauge to 16, and even 18. The AMPs measured seem low enough on the circuit, KOEO, about 7.5, that is a total for the 3 fuse bar in the panel. One thing I did notice, that while measuring at the brown @ R/R, and powering each of the two other circuits on the fuse buss bar, I had a slight feed. This tells me some where in the old girl one or more of the 28 year old parts, or connector is "Bleeding" a bit, from corrosion or maybe a diode. Once again the Storms have brought the job to a quick halt for today.
- loudhvx
13 Aug 2010 06:39 #390581
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Most of us have come to the same conclusion that the coil-relay-mod, while it does address the voltage at the coil, may mask a problem of low voltage on that brown wire. That may lead to overcharging and the subsequent failures. We usually recommend fixing the underlying problems if possible, but sometimes people just need a shortcut to get it running. And in some cases the relay may re-route enough current to restore some of the voltage to the brown wire. But without any cleaning/fixing, the drops will eventually return.
1981 KZ550 D1 gpz.
Other links.
- Motor Head
13 Aug 2010 06:47 #390582
by Motor Head
Yes, on this bike everything is so unmolested, original, had been in storage, (Garaged) for all its life. I really want to be doing the bike justice with a Factory look repair. So again it is a beautiful cloud free morning, as with nearly each and every, but by noon storms are again forecast. I am going to pull the fairing so I can get into the "Bucket" and also the Tank, with the side covers off, and see if I can locate this small "Bleed" of current/ volts. Maybe unplug then clean every connector will be enough?
- Motor Head
13 Aug 2010 13:45 - 13 Aug 2010 14:32 #390690
by Motor Head
OK so I'll say I found 3 problems, one is the Vetter Fairing Installers Fault. The PO or shop that had "Wired" in the Vetter harness was a goof, scotch locks, probably in the kit, and the running light feed for the front was taken from the right handlebar Ignition and start switch Brown wire. So there was a slight load on the Brown that was not Factory. Of course now it is on the correct running light circuit. Then the Second problem is one most would expect, slight green corrosion starting in the main Ignition switch, a disassemble cleaning and fresh Dielectric grease fixed that. Then the third was that one connector in the Head light bucket was just dirty from those buckets not being sealed, picked up .1 Volt here, and I also had the fuse panel removed from the bike, completely cleaning all contacts, but also taking the back off and inspecting the wires and underside of the contacts for heat damage. I also ran the bike and with my RayTech thermometer tested for heat issues at various points in the fuse panel and harness.
So after a few hours of fooling around, and testing mostly for Voltage drop on the Brown wire, Verses Charging Voltage at the battery, I now have 14.6 across the Batt terminals at 4000rpm. I call it good enough, because I really want to be able to NOT chop up this beauty. If for some reason I Boil a battery, which has not happened yet, as I just checked the water level, I may consider rerouting some circuits.
On that i think I would look at redoing the buss bar in the fuse panel, on this model. Making where the Ignition switch feed white/ black coming into the buss bar gets its AMP load lightened. This would effectively raise the voltage on the brown. I would separate the three terminal buss taking the head lamp feed off, and resupplying the feed for this 1 fuse with a load relay used for head lamp applications from a Jap Car. I think there are some with the right wire colors on the harness pig tail, it could be cut out of a car at the wreckers cheap. The head lamp circuit is by far the higher AMP load on the buss bar. Why Kawasaki didn't feed the head lamp with a separate circuit in and out of the fuse panel, and Battery through Ignition switch is another debate.
Last edit: 13 Aug 2010 14:32 by Motor Head. Reason: Edit
- MFolks
13 Aug 2010 15:16 #390694
by MFolks
Those Scotchlocks are nothing but trouble, they are not sealed againt moisture. When somebody istalls a Dyna "S" electronic ignition, I tell them to throw away this cheap splice and use solder and heatshrink tubing for a far better electrical connection.
I've read of people being under a trailer during a pouring rain troubleshooting the light and braking circuit due to these splices.The trailer wiring installer did the installation cheap and fast.
- MFolks
13 Aug 2010 15:46 #390696
by MFolks
Motorcycle Wiring Repair Supplies
72-7750
Dry Vinyl Tape From Tape Brothers
www.tapebrothers.com
Dry Vinyl Tapes are non-adhesive plasticized polyvinyl chloride film tape. Easy unwinding characteristics - tape clings firmly to it’s own backing for tight wrap. High elongation and good strength to permit trouble-free binding of wiring harnesses for the automotive industry. Dry vinyl tape also used for plating applications- high stretch, good “cling†characteristics and great conformability provide for superior masking in hard chrome and other plating applications.
DVT-76B 2 in. x 250 ft. Black Dry Vinyl Tape
Our Price: $6.54 Per Roll
www.wiringharness.com
• Non-Adhesive Vinyl Harness Tape, made to the original mil-thickness.
• Just wrap it tightly around the wires and knot the end.
• 100 foot roll is enough to do 3 to 4 harnesses complete.
• Available in three different widths, as original.
• Correct for all years (1955 to Present).
Part # Description Price
R0058272 3/4" Vinyl Harness Tape, 100 foot roll $12.00
R0058276 1" Vinyl Harness Tape, 100 foot roll $13.00
R0067108 1-1/4" Vinyl Harness Tape, 100 foot roll $15.00
www.keefeperformance.com/silicone_tape.html
"36 Foot" roll of Self bonding silicone tape
High temperature silicone tape
This Mil-spec silicone tape is Rated up to 500+ degrees
Made of silicone rubber, this self fusing silicone tape will protect most all electrical wiring, connectors, hoses, spark plug boots and more from extremely high temperatures. The self vulcanizing process automatically begins when the two sides of the tape are put into contact. A catalyst on one side of the tape begins the bonding process as soon as wrapping takes place.
great for all electrical wiring, harness, cable, and hose applications
Colors: Red and Black
Exceeds MIL AA-59163 TYPE 1 & 2
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
Electrical, Home, Auto, Truck, RV, Marine, Motorcycle, Military, Commercial, Industrial, Generator
Heat Shrink Butt Splices From Cable Organizers
www.cableorganizers.com
PART # WIRE GAUGE COLOR PACK QTY PRICE
NSPA-KS5-20 22-24 AWG CLEAR 50 $13.89
NSPA-KS5-16 18-20 AWG RED 50 $13.49
NSPA-KS5-14 14-16 AWG BLUE 50 $13.82
NSPA-KS5-10 10-12 AWG YELLOW 50 $16.48
_____________________________________________________
72-7750
ASTM-D 2137 / -65C
ASTM D-412
ASTM D-149
- Motor Head
13 Aug 2010 17:26 #390712
by Motor Head
Great stuff, as I think there is always a reason to try and do the job right the first time. These links help everyone with where to get quality supplies when working on their electrical!
- loudhvx
14 Aug 2010 10:08 #390824
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Nice job on tracking down the Vetter install error.
Soemtimes jsut cleaning is not enough, if the outer plating is gaone on the contacts. After it's gone, cleaning will work for a little while, but usually it will corrode faster.
Yeah I agree that it would have been better to route the lighting load independently from the ignition/charging circuits. The lighting already has it's own fuse, so why put it through the main as well. There may be a reason, but I can't see it off the top of my head.
1981 KZ550 D1 gpz.
Other links.
