Correct spark plug for KZ750 L3 with Kerker pipe?
  • staniel
  • staniel's Avatar Topic Author
06 Aug 2010 18:21 - 06 Aug 2010 18:22
#388791
I took my head in to a shop to get some work done. I learned a ton in the process, but that's all in a different thread. Along with the head, it seems I left the plugs with the shop and now I don't have them anymore.
The parts list at kz.mbsween.com/parts.html / kz.mbsween.com/parts/C-11Ignition.jpg suggests a few options, starting with B7ES.
Does anyone have one of these with a Kerker exhaust (I think this was an available option in '83)?
I recently had the thing rejetted, so all should be tuned to the exhaust, but I wonder which plugs I should get? I saw a couple threads suggesting B7ES as the go-to... Maybe I should get them as a baseline and then go up to B8ES if they aren't hot enough?
Have I mentioned that I love kzrider.com?
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
Last edit: 06 Aug 2010 18:22 by staniel.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Correct spark plug for KZ750 L3 with Kerker pipe?
06 Aug 2010 19:06
#388811
B7es is hotter then B8es is hotter then B9es
B8es would be my choice.Most KZ's were factory specs. with this heat range.If running temp is excessive and/or preignition try B9's
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • otakar
  • otakar's Avatar
06 Aug 2010 19:25 - 06 Aug 2010 19:26
#388817
On a small cylinder the B7 is the right plug. I wouldn't go to a B8 until you start getting close to 900 The smaller the bore the hotter the plug. The KZ1300 also used the B6 plug because of the 62mm bore. The idea is, to use the hottest plug that you can, that will not cause detonation.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 06 Aug 2010 19:26 by otakar.
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 Aug 2010 21:14
#388842
B7's are the stock plug for the KZ650,62 mm bore.
Is the KZ1300 water cooled?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
07 Aug 2010 04:25
#388866
FSM specifies B8ES for KZ750, Z1, Z2, KZ900, KZ1000, and KZ1100
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • staniel
07 Aug 2010 07:48 - 07 Aug 2010 07:53
#388900
After posting this, I found out that the Clymer manual says B8 for normal weather and B7 for cold temp (I'm in Seattle, so, not cold). The manual doesn't know about the Kerker pipes, but I guess that's not too big a deal. For now I'm planning on the B8ES. They're both within range, and I think I'd rather slowly melt a set of plugs than risk detonation (just looked it up) and have to get a new set in a few days. I guess either one would work..
Last edit: 07 Aug 2010 07:53 by staniel.
  • staniel
09 Jun 2015 14:02
#675910
Here's almost 5 years later. I've been running B8ES for a while, and it's been alright. I do a lot of desert riding.
