KZ440 No Spark, No lights. New Solenoid & Battery
- dckareem
25 Jul 2010 11:59 - 26 Jul 2010 19:27
to make this short. there is no power at all no spark, no lights. it will rev with a jump but no spark. don't know if i need a transistor ignitor, new coils or a start switch. the battery has a charge and a new starter solenoid.
Last edit: 26 Jul 2010 19:27 by dckareem.
- dckareem
Re: KZ440 No Spark, No lights. New Solenoid & Battery
26 Jul 2010 19:28
dont want to buy the wrong thing. First kz and bike i have ever bought
- MFolks
26 Jul 2010 19:34
I'd look at your fuses, I suspect a 20 amp main fuse it blown. Also look at this:
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1†long. Most good auto parts stores can get them for you. They are ¼†in diameter.
2. The more common AGC is 1 ¼†long and may not fit the smaller fuse clips. Again, ¼†in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade†style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini†Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade†style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net www.delcity.net/cartviewitem?item=73805&search=y
- dckareem
26 Jul 2010 19:42
im going to check the fuses they look good, but ill get some replacements just in case and let you know
- MFolks
26 Jul 2010 19:56
If fuses check good, have battery fully charged and load tested followed by hydrometer test(floating balls indicating percentage of charge).
If battery is good, check wiring for corrosion at connectors and then look at ignition switch and right handlebar run/stop switch.
- dckareem
27 Jul 2010 18:20
1.changed fuses still no power
2.New Solenoid makes noise when i press the start button but not spark.
3. this all happened when i used a screw driver on a bad solenoid to make it start.
4. wires look fine. screws on the battery are old and rusty not sure if it corrosion.
5.still no lights, still no spark.
- MFolks
27 Jul 2010 18:31
Battery fully charged? electrical conections must be clean and tight for maximum current flow. Check the Negative(-) cable going to (Usually a engine mounting bolt) for tightness and corrosion.
27 Jul 2010 23:27
dckareem wrote:
With ignition switch in ON position, ignition coil must be receiving battery voltage in order to produce spark.
Would measure the voltage at coil primary terminal.
...no spark.
- dckareem
28 Jul 2010 10:55
i checked the ground its on there tight unless there is another one.
i cleaned the battery because it had a corrosion on the positive connector side.
Still no lights, no spark.
When you hook it up to a charger the engine revs up but still no spark or lights. just a revving noise.
I only can assume its the starter coil or transistor igniter.
- Kawickrice
28 Jul 2010 10:59
Check the bunch of wires in the headlight bucket. There are lots of plugs that could have possibly came loose. Your stater turns over so that is a good sign. Follow the whole harness and check all the connections along the way
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- dckareem
30 Jul 2010 18:22
if there is no power going to the ignition coil. i can assume its a fried wire?
- MFolks
30 Jul 2010 18:28
No, check the right switch pod as this is where the coils get the voltage. Also the run/stop switch may have corrosion on the contacts.
If no voltage there, start by looking at the ignition switch as they fail over time.
