God i hate this bike
  • RobQ
  • RobQ's Avatar Topic Author
22 Jul 2010 14:41
#384639
1981 kz550 ltd started up yesterday and ran fine around the parking lot. And today, pressing the starter button, and nothing happens. Doesnt even click?? Battery is fully charged
  • bountyhunter
  • bountyhunter's Avatar
Re: God i hate this bike
22 Jul 2010 14:51
#384643
Could be anything from starter solenoid to ignition switch. Does your bike have any of those goofy "lockout" switches that disable everything like the ones on the clutch lever or side stand?
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
22 Jul 2010 14:51
#384644
Do the headlight, neutral light, and oil light come on with the key on?? Check to make sure your battery connections are tight. Clean them up with a wire brush and if that doesn't work then wiggle them while you hold the start button down.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • RobQ
22 Jul 2010 15:01
#384645
all lights, horn, turn signals work. And like i said it ran fine yesterday. I took off the gas tank last night and rewired the lines because they were wrong and put the tank back on and tried it this morning. Ridiculous. Just put it on craigslist for 500 because im a newbie and want nothing else to do with this bike.
22 Jul 2010 16:08 - 22 Jul 2010 16:13
#384659
If not already done, would also check the "Kill" switch (aka OFF-RUN-OFF) switch on right handlebar switch gear to assure it's in RUN position (i.e., the middle click).
Good Fortune! :)
Last edit: 22 Jul 2010 16:13 by Patton.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
22 Jul 2010 16:11
#384660
Just my opinion, and not to be unduly inflammatory, but I think you lack the patience and maturity required for motorcycle ownership.
Sell it.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • Skyman
  • Skyman's Avatar
22 Jul 2010 17:00
#384663
Sell it.
Agreed. And this isn't intended as an insult to the OP, but it definitely takes a certain...personality to own a vintage bike. And that personality includes having enough patience and willingness to track down and fix the little problems that WILL happen from time to time. And not only patience, but also the ability to find some excitement from the process of working on your own bike.
If that doesn't describe you, and you just want to have a trouble-free ride that you can take to a mechanic if a problem ever occurs, then I agree that you should sell it and get something newer.
But, as a suggestion to the OP, sometimes it can be as simple as corrosion in the starter button. Sometimes you can just twist the button 180 degrees, and it will fire up.
West Linn, OR
  • RobQ
22 Jul 2010 18:02
#384674
i have the patience but just not the knowledge of vintage bikes. If i owned my own house and had a career id keep the bike because i would have ample work space and more than a $9 hr job income. But being a grad student with 20 page papers due every month, a bike that needs work just isnt for me. i got it running just cant keep it running. no harm tho, you didnt hurt my feelings
  • bountyhunter
22 Jul 2010 18:06
#384677
Sell it.
:laugh: What a coincidence.... I was riding my old KZ750 yesterday and I noticed the tach stopped working. I stopped and looked and the tach cable had worked loose and fell out of the tach fitting. End of the cable was sitting there spinning.
Old motorcycles are not like new cars, they are more like girlfriends on PMS. They take a lot of understanding to live with....
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
22 Jul 2010 18:14
#384685
:laugh: :laugh: :laugh: :laugh: :P
:P Nailed it!!!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • trianglelaguna
  • trianglelaguna's Avatar
22 Jul 2010 18:43
#384718
mine on my 900 has been needing a fews wiggles/toggles on nthe kill switch some times....Patton wrote:
Good Fortune! :)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Old Man Rock
  • Old Man Rock's Avatar
22 Jul 2010 18:58
#384721
DOH!!! Tough crowd.... :pinch: :whistle:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
