Mirrors?
  • Topper
  • Topper's Avatar Topic Author
Mirrors?
10 Jul 2010 05:14
#381434
I recently purchased a 1988 KZ305 LTD. It didn't have any mirrors on it and I bought a set of "universal" mirrors that look similar to what I've seen on this bike.
The mirrors fit just fine, but no matter what I do I can't adjust them to a point where I can actually see anything in them.
This KZ305 has the original swept back handle bars on it. I'm wondering if that's part of the problem as it puts the mirrors at a funky angle.
Has anyone else had this problem? Do I need to get a particular set of mirrors to ensure they'll actually work?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • otakar
  • otakar's Avatar
Re: Mirrors?
10 Jul 2010 06:54
#381451
Without seeing pictures it is hard to help.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Mirrors?
10 Jul 2010 07:06
#381453
You can use washers to get a better seat angle on the bar.
Start with 1 washer and then grind/double as necessary.
You dont need special mirrors, just a little mounting trickery.
You should be able to obtain a fairly 360 degree field of vision with properly mounted mirrors, and the horizon should be right across the middle of the mirror.
GL!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Topper
Re: Mirrors?
10 Jul 2010 07:12
#381456
I'll try to take some pics today.
1979 KZ750 Twin
  • Topper
Re: Mirrors?
10 Jul 2010 07:52
#381466
Here's the left mirror
1979 KZ750 Twin
  • Topper
Re: Mirrors?
10 Jul 2010 07:54
#381468
and a view of the back.
The longest part of the stem is about six inches long. No matter how I try to adjust these I can't see anything useful in the mirrors.
Do I need a different style mirror for this bike?
1979 KZ750 Twin
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Mirrors?
10 Jul 2010 07:55
#381469
I just went through this on my KZ where I either had tuck in my arm and shift amy body slightly to see or rotate my elbow up to see under the armpit/hip... Looked like a freaking chicken going down the road.... :S
There was numerous things I didn't care for about in my original mirror selection, so went a different route...
Not sure I like this style mirror (theme, prefer 3" rounds I think) but had these as spares and it works a hell of a lot better during a ride... Clear and un-obstructed views....
Under bar Mirrors!!!!
As can be reviewed in the lower image, plenty of clearance to tank....
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Mirrors?
10 Jul 2010 08:01
#381470
Just a thought...
OMR
not sure what kind ofbug that is,but these guys might have the answer! www.killsbugsdead.com/solutionindex.asp :woohoo:
  • otakar
  • otakar's Avatar
Re: Mirrors?
10 Jul 2010 08:52
#381484
For this application the mount points were not at an 90* angle which on these mirrors they are. You will have to "twist" the long leg of the rod. You can see the angle in this picture.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
Re: Mirrors?
10 Jul 2010 08:54
#381485
Just a thought...
OMR
Don't pay any attention to Rocks bike, he rides the thing standing on his head. :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • RonKZ650
  • RonKZ650's Avatar
Re: Mirrors?
10 Jul 2010 09:47
#381489
Hopefully the mirror uses convex glass. (Objects are closer than they appear). If not, no need to bother with them as they are worthless. I can't believe how many aftermarket mirrors are not convex! Garbage.
  • Topper
Re: Mirrors?
10 Jul 2010 11:19
#381508
Your pic isn't showing up, but I'd love to see it.
1979 KZ750 Twin
