Need a wiring Diagram
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
27 Jun 2010 22:20
#378688
I was wondering if you guys could give me a wiring diagram for only the wiring required for the engine to run including the battery and ignition switches. I was going to get rid of my gauges and wire in my own lights for my bike if it runs good after this starter clutch thing. I was planning on doing an overhaul on the wiring harness thats in it now but why no just sell the original and make my own custom harness...
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • bountyhunter
  • bountyhunter's Avatar
Re: Need a wiring Diagram
27 Jun 2010 23:58 - 27 Jun 2010 23:59
#378691
Making a harness by hand is a lot of work. If yours is flaky, you might want to buy one off fleabay and just use the parts you want like ignition, fuse connects, lights.
Last edit: 27 Jun 2010 23:59 by bountyhunter.
  • Old Man Rock
  • Old Man Rock's Avatar
28 Jun 2010 05:29
#378710
Here you go Tim... pretty much the same on your 1000...
I'll follow up with this drawing with electric start for ya as well...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
28 Jun 2010 05:43 - 28 Jun 2010 05:47
#378711
With starter....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 28 Jun 2010 05:47 by Old Man Rock.
  • Old Man Rock
28 Jun 2010 05:48
#378712
:angry: Trying again...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Kitten Tooth
28 Jun 2010 15:58
#378803
You rock old man rock:) Thanks for all the replies.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Jun 2010 18:25
#379069
Here's one a 650 owner drew up:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • kzbobber1
  • kzbobber1's Avatar
29 Jun 2010 19:54
#379099
Old man Rock, will that diagram work for a 82 kz750? If not could you give me one that is bare bones but will have headlights, tail lights, turn signals, and an electric start button? Dumb question, what are all the little black double bar looking things in the diagram? I dont know much about wirring. Thanks
  • Motor Head
  • Motor Head's Avatar
29 Jun 2010 19:57
#379100
I think you are looking at the grounds.
  • kzbobber1
29 Jun 2010 20:05
#379101
no, those look like little rakes. lol. coming off of the rectifier and the ingnition and key switch etc. there are a few sets of 2 black bars that look like they break the wire. Dont know what those are. thanks
  • Motor Head
29 Jun 2010 20:08
#379103
Ah, those are they way it is drawn, a published circuit would have shown a slight loop around. This is just showing that the wire continues and does not connect at those intersections.
  • kzbobber1
29 Jun 2010 20:16
#379107
the only other question is, on the diagram, the ignition switch has two wires that dont look like they go to anything. are those the wires that would go to lights etc?
