Need a wiring Diagram
  • TerryK
  • TerryK's Avatar
Re: Need a wiring Diagram
29 Jun 2010 20:20
#379109
Old Man Rock wrote:
:angry: Trying again...
This could help me with my problem as well Rock! I don't need lights at the drag strip anyway right? :P
Thanks!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Motor Head
  • Motor Head's Avatar
29 Jun 2010 20:22
#379110
Not my diagram, but can;t see what you mean. All wires from the switch, in that drawing, are connected. Battery, then Feeding the load side of relays from the looks of it.
When the relay closes then it will let the voltage and current through to the device.
  • TerryK
  • TerryK's Avatar
29 Jun 2010 20:51
#379117
So....how the hell do I print the full sized picture? lol
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Motor Head
29 Jun 2010 20:56
#379120
right click, then copy, reopen by pasting in a program such as WORD.
  • TerryK
  • TerryK's Avatar
29 Jun 2010 21:01
#379121
Tried that, didn't work, tried it again, it worked. Thanks!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Old Man Rock
  • Old Man Rock's Avatar
01 Jul 2010 14:07 - 01 Jul 2010 14:12
#379480
The two Black Bars indicate a harness/panel multi-conductor connector.... NOT GROUNDS.... Sorry, not trying to insult but please do not attempt tying your ignition switch white or brown conductors to ground....
The white is your power feed into the ignition switch, brown is the passed power to the coils, charging system (electrics) and lighting....
I updated the drawing depicting the colored electrical panel connectors...
The non terminated Blue & Red conductors off the ignition switch would be for lighting....
As far as the KZ750 (or any other KZ), follow your wiring diagrams in the same manor for bare minimums... Concept is pretty much the same...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 01 Jul 2010 14:12 by Old Man Rock.
  • Old Man Rock
03 Jul 2010 07:00 - 03 Jul 2010 07:06
#379877
@ kzbobber1...
For a '82 KZ750 use this instead, should get you going...
Image file too large... I'll pm you for e-mail info....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Jul 2010 07:06 by Old Man Rock.
  • Old Man Rock
03 Jul 2010 07:31 - 03 Jul 2010 07:32
#379884
Figured all hell with it, someone else may need it so here's the link to download the 11" x 17" pdf image of it....
kzrider.com/index.php?option=com_docman&...d&gid=482&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Jul 2010 07:32 by Old Man Rock.
  • Old Man Rock
03 Jul 2010 07:34
#379885
Forgot... this was off a 1982 KZ750-R1 wiring diagram...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
