- Thank you received: 15
LED Signals....relay
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- Old Man Rock
- Thank you received: 225
1 for +12Vdc (switched off ignition switch)
1 for ground
1 for LOAD... This is you control switched led turn indicator...
Tridon relays... Most auto parts store carry them if anyone else is interested....
www.tridon.com.au/Products/Product.aspx?SG=8&S=35&G=478&P=2000
Here's how I did my 900...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- Old Man Rock
Right out of the manual, can't explain it any better then this... See red boxed text....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
- Thank you received: 337
I believe that's correct. A standard unit is a bimetallic metal strip in series with the bulb, so you only need two lines: power in and power out to lamp. The electronic ones are run by 12V (power in) and drive the bulb on power out, but would need a ground for the timer circuitry to be able to run correctly. It's my understand that the solid state relays contain no mechanical relays, they use a 555 timer and a FET or some solid state device as a switch. A relay alone is probably not going to work unless there is some circuitry to run it.I put a set of LED signals on my bike, they won't flash with the original flasher. I picked up an electronic flasher from Napa, I'm assuming it will work, but I'm curious if anyone has ever put one in, this relay has three prongs where the original is only two. I'm assuming the third prong is for a ground?
- Old Man Rock
Yes... The EP35 is a 3 wire device, plug it in as depicted in the drawing and mentioned in text.... This unit worked due to 21 watt load/current sensing of my LED signals.... May not work for yours....
"No resistors or such have to be used?"...
Non what so ever.... Not required...
"Also, you say that the relay should be a non-load sensitive type. The one pictured and the one that I bought say that they are load sensitive.
Do you know a part number for the correct relay in non-load sensing?"....
Already provided.... Tridon LED-4...
There's many options out there for relays if you know the current totals of your turn signals... Find the ones that depict no load/LED sensitive and you should be fine....
Most motorcycle shops carry non resistor type relay flashers as well.... If you have a Cycle Gear shop around, they have them there as well.....
Try to stay away from the "Include resistor" packages for this is one of the reasons you went LED is it not, to reduce current demands in an old wiring harness/electrical system....
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
www.cyclegear.com/spgm.cfm?L1=5000&L2=7&...=&item=PRC_SM-FRH1_G
On a KZ900....
The red would terminate to switched +12Vdc
The black to your Orange from turn signal hand control...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
The relays are designed for +12Vdc operations...
The KZ voltage increases above this at higher rpms ~+14Vdc...
With that in mind and for simplicity...
Lets say your initial non working situation/load/current demands is at 6 ohm load.... but your relay is rated at a minimum of 2.2 amps...
12Vdc/6ohms = 2 amps obviously no worky....
But at 14Vdc/6ohms it now equals 2.333 amps where now the relay is operating within specifications thus worky....
OHM's law, never fails... Just the way it works folks....
And yes Adam... OHM's law works in Canada as well.... :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- madmatt1
1977 KZ1000 LTD
1977 KZ1000A
- otakar
www.superbrightleds.com/cgi-bin/store/in...pecs/CF12ANL-01.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
