Oil light on when clutch engaged
- Maltraxxx
- muddy1
- 1980 Kz1000 LTD B4
Re: Oil light on when clutch engaged
18 Jun 2010 15:48
Have you recently changed the oil? Could be trapped air in there (filter) ....
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- Maltraxxx
18 Jun 2010 15:53
I just bought the bike and the next thing I do is change oil and filter. Maybe it will help...
- PLUMMEN
18 Jun 2010 18:19
what kind of bike is it? is it when you start to release the clutch and put a load on the motor?
- Maltraxxx
18 Jun 2010 18:22
It's a 1984 ZN1100. And no its the opposite, its when I pull the clutch, not when I release it. Sorry if i expressed myself wrong, I'm french...
When I pull the clutch lever, the oil light turns on and stays on until I release the clutch lever.
- MFolks
18 Jun 2010 20:52
I suggest opening up the headlight housing and see if a wire or two hasn't rubbed together. These are two seperate circuits and should not interact like this.
Vibration and the way wires are routed may attribute to this.If your bike is like the U.S. models, the clutch lever needs to be squeezed(pulled in) to start the engine.
It's another safety feature Kawasaki added to prevent starting the engine in gear.
- Maltraxxx
19 Jun 2010 12:02
Sorry guys, I was wrong in my symptoms analysis. The oil light turns on when the THROTTE is released, not when the clutch is engaged. These 2 actions often happen at the same time, thats why i thought it was linked to thew clutch.
When I give gas, the light turns off and when i stop the gas, it turns on.
- Kawickrice
19 Jun 2010 12:32
Check your oil level
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- hocbj23
19 Jun 2010 12:34
These old bikes only operate with 2-3 pounds of oil pressure anyway,so it is important that the oil type and weight meet factory spec and there is the proper amount of oil in the bike.have u changed the oil and filter recently?Did u check the oil pump screen to be sure it was clean and not all clogged up?do u happen to have an oil cooler on the bike? Is it working properly?Have u taken the wire off the oil pressure sending unit and cleaned the connection.?Good luck.bj
- DoubleDub
19 Jun 2010 13:10
Maltraxxx wrote:
This sounds opposite of most normal oil pressure switch issues as I've heard them. Usually it's when the bike is "launched" from a standing start that the oil pressure goes low. Why would the oil pressure switch complain when the oil rushes forwarded during deceleration?
- Maltraxxx
19 Jun 2010 13:53
Oil level is fine if not a bit high, but it wouldnt explain my problem. I rode the bike only twice 5 km since I own it... I didnt notice if it did that the first time.
I dont understand how that could possible: low oil pressure when idling? Euh....!?!?!
19 Jun 2010 14:46
Maltraxxx wrote:
When throttle is released and oil light turns on, is either brake being applied?
What if bike speed is reduced from say 60mph to 20mph by cutting back on the throttle, but not closing the throttle, does oil light come on then as well?
