1978 kz750 twin
- Truc
04 Oct 2012 01:26 #552354
by Truc
dont think this will work on my bike, the mount points are 4" apart... not 3.5"
Replied by Truc on topic 1978 kz750 twin
bountyhunter wrote: Here is the 4 Ohm coil which is the functional replacement for stock 750 twin coil with points ignition. It is definitely a single coil system. All of the 750 twins from '76 - '79 used 4 Ohm coil/points ignition. I think some of the 400 or 440 twins had electronic ignition, not sure what years.
This coil is for any points system:
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
- Thank you received: 2098
04 Oct 2012 01:49 #552359
by Patton
Was continuity measured between ends of the spark plug wires with the caps off?
Should be very high ohms, such as 18K or maybe higher (guessing).
If no continuity, perhaps one of the caps is defective (if measuring between the caps attached to the plugs).
It's sometimes possible to snip a short section from the plug wire ends to provide better connections with the caps (in case the wire-cap lacks continuity).
Replied by Patton on topic 1978 kz750 twin
Truc wrote: ...no continuity between sparkplug wires.
on the hunt for one before buying a new one
