1978 kz750 twin
- INDYIRONS
Q; HOW DO YOU TEST THE COILS AND WHERE DO I HOOK MY OHM METER TO THEM?
ALSO.. WHAT SHOULD IT READ... ITS A DUAL COIL SYSTEM?
ANY HELP WOULD BE GREAT.
THANKS GREG
- bountyhunter
- Thank you received: 337
There honestly is no way to accurately test a coil. The primary side should read about four Ohms resistance. I think the secondary is maybe 10k or that ballpark?
However, most old coils are bad because they are failing due to a high voltage "arc" internally and there is no way to test this.
Z1 sells an EMGO four Ohm coil for $36 that will work. I am running one and it is hotter than the stock coil (bike starts easier).
- INDYIRONS
- Thank you received: 2098
whats the website for z1?
Hello, Greg, and WELCOME to KZr!
We're glad you're here!
For Z1E website, click > www.z1enterprises.com/
- MFolks
- Thank you received: 540
1.Lack of cooling air; where they are mounted under the gas tank traps the heat from the engine and the only cooling is when the bike is moving.
2.Vibration; the coils are not isolated from the many various frequencies and amplitude of vibrations.Over time and heat the internal insulation will fail.
- basketcase
I had a single coil from a honda and the spark was very weak. What made my mind light up was checking a chain saw I was rebuilding the spark on that was bright and made a crispy sound where the KZ needed the door closed and was intermittent. I don't think I went wrong ordering a new coil and points setup. Fresh is fresh and my old basketcase needs as much help as it can get.
Still embarrassed to post pics.
Jeff
1979 KZ750B4
Basketcase
- Truc
where did you find the coil for sub $40...?
anything else to look at? anything in the ignition that is known to fail?
thanks guys!
A defective coil is only one of several possible reasons for failed spark.Truc wrote: hey guys, im tearing apart my KZ trying to get her to spark. thinking its the coil too. where did you find the coil for sub $40...? anything else to look at? anything in the ignition that is known to fail? thanks guys!
Has the coil been ohm-tested?
- bountyhunter
It is the 4 Ohm Emgo coil that sells for $36. I can't post a link because the Z1 server is stone dead, won't open from any of my three browsers. They really need to fix that thing it is beyond annoying.Truc wrote: hey guys, im tearing apart my KZ trying to get her to spark. thinking its the coil too.
- gumby prichard
- Thank you received: 1
when i bought my bike it had a 4cyl coil on it.
I ended up buying an dynatek electronic ignition which required a higher resistance coil. I bought a 4 ohm coil to compensate for the resistance.
as long as your coil(or coils, if single output) is between 2-4ohms you should be fine. But if you have a 4ohm coil you may have problems with weak spark due to high resistance.
see patton and bounty hunter, i listened. :lol:
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
This coil is for any points system:
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
The bikes with electronic ignition use a lower resistance coil (like 2.2 - 3 Ohm range). You can use the 4 Ohm coil with electronic ignition but it may put out a bit less energy, not sure if you will notice any difference.
- Truc
Patton wrote: A defective coil is only one of several possible reasons for failed spark.
yeah, finally. its done. no continuity between sparkplug wires.
on the hunt for one before buying a new one
