turn signal stem?
- b.tracy79kz
turn signal stem?
05 Jun 2010 12:31
i bought short stems for back,but i want to install shorts to the head light brackets.but the rears have a diamond spacer,and the head light brack dont.do they make one for what im looking for?
- anarki650
Re: turn signal stem?
05 Jun 2010 13:29
Can tou slide the plastic spacers off the old stems and use them on the new short stems?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- JMKZHI
05 Jun 2010 20:13 - 15 Jun 2010 06:49
If yours are the aftermarket type w the metal diamond as part of the casting, you could get the stock type instead & remove plastic sleeves. Z1Enterprises.com should have something. I guess the fitment will be fine.
Another alternative is to get KZ440 front turn signal stems - e.g. 1980 KZ440-A1. Again, I don't know how the fitment will be - not sure if the threaded end is long enough for your application. The cross-reference in the diagrams at Kawasaki.com will show what other bikes use them.
Also, some early Honda stems might work as well, but I don't recall what model(s) - CB750? perhaps? Or maybe one of those other CBs. Someone on another Kaw forum put them on his big KZ.
Last edit: 15 Jun 2010 06:49 by JMKZHI.
- JMKZHI
05 Jun 2010 20:21Attachments:
- JMKZHI
05 Jun 2010 20:27 - 05 Jun 2010 20:40
Also from ebbaayy: aftermarket CB750 stem.
Edit: I believe PartsnMore.com has these stems listed under the CB750 SOHC for six bucks apiece, but the quality probably isn't that great. $35 minimum order.
Last edit: 05 Jun 2010 20:40 by JMKZHI.
- JMKZHI
05 Jun 2010 20:30Attachments:
- seanof30306
10 Sep 2010 03:38
Could you use these short stems with aftermarket signals?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- JMKZHI
10 Sep 2010 08:07
They work w aftermarket replica Kaw turn signals. My guess is that turn signals of the era are kinda universal fit. I don't know if newer signals will work or not - I've never checked into them.
- bucky242
30 Nov 2012 04:11
Any recomendations for doing a front blinker delete.
Blue 1980 kz440 b1 with clubmans 2 to 2 exhaust rejetted carb.
Last edit: 23 Jan 2013 12:46 by martin_csr.
30 Nov 2012 11:46 - 30 Nov 2012 11:46Hello, bucky242, and WELCOME to KZrider!bucky242 wrote: Any recomendations for doing a front blinker delete.
Is the objective to remove the signal lights altogether, or to merely disable them?
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Last edit: 30 Nov 2012 11:46 by Patton.
- bucky242
30 Nov 2012 15:46
1980 Kz440 b1 and yes it's legal you just need back ones of they came with the bike.
