turn signal stem?
- b.tracy79kz
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- JMKZHI
- Thank you received: 48
Another alternative is to get KZ440 front turn signal stems - e.g. 1980 KZ440-A1. Again, I don't know how the fitment will be - not sure if the threaded end is long enough for your application. The cross-reference in the diagrams at Kawasaki.com will show what other bikes use them.
Also, some early Honda stems might work as well, but I don't recall what model(s) - CB750? perhaps? Or maybe one of those other CBs. Someone on another Kaw forum put them on his big KZ.
- JMKZHI
- JMKZHI
- JMKZHI
- seanof30306
- Thank you received: 2
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
- JMKZHI
- bucky242
Blue 1980 kz440 b1 with clubmans 2 to 2 exhaust rejetted carb.
- Thank you received: 1656
- Thank you received: 2098
Hello, bucky242, and WELCOME to KZrider!bucky242 wrote: Any recomendations for doing a front blinker delete.
Is the objective to remove the signal lights altogether, or to merely disable them?
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
- bucky242
