Dyna-s installed "easy"
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Dyna-s installed "easy"
05 Jun 2010 10:45
#373657
Still discerning on the 2 volt drop but "Across the battery while running 4,000 rpm's 13.5v" is good...
In case you haven't seen this, here's how the jetting interacts and over laps each other throughout the rpm range...
If choke circuits are working/not hanging up and pilot screws are adjusted to spec.... may be time for some jetting changes...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
05 Jun 2010 10:50 - 05 Jun 2010 10:51
#373661
This is where the Gunson Color Tune would come in handy... You'd be able to see if you're running too rich and not able to adjust for leaner ops...
Good trouble shooting tool to have as well as tuning aid... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Jun 2010 10:51 by Old Man Rock.
  • bill_wilcox100
  • bill_wilcox100's Avatar
05 Jun 2010 10:55 - 05 Jun 2010 10:58
#373663
I had the same "Black Sooty Plugs" symptom when I first got my bike a few years ago.
I installed the "Coil Re-powering" mod and the symptom disappeared immediately. Many, many members have got their rides back on the road with the help of this mod.
This is how I did mine.
[img=http://s259.photobucket.com/albums/hh311/bill_wilcox100/1-Relay%20Modifications/?action=view&current=WireingModsK1K2K3Issue10.jpg][/img]
See more details here. Link
True, this does not hunt down the eliminate high resistance point fault.. but first-things-first, ride.
Best of success, :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 05 Jun 2010 10:58 by bill_wilcox100.
  • Old Man Rock
05 Jun 2010 10:57
#373665
Ah here we go.... :whistle:
If 13.5Vdc at coils at 3500rpms, what does this circuit do again... :whistle: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • ken
  • ken's Avatar Topic Author
05 Jun 2010 11:09
#373670
Kawickrice wrote:
After reading the post it seems you have cover most of the bases more than one in some cases. I couldnt help but notice you said twice that you have not put in the denso's because of the cost. I would go and buy a "new" set of plugs and see what happens. Sounds like you have fouled the plugs many times over.
My .02 cents
I put the Denso's in, went about 8 miles and pulled one, and sure enough black and sooty (except #2, it's ran good from the start.) Next step is going thru the diagram Patton posted and check one thing at a time. After the secong time of cleaning all the connection I had 11.7v going to the coils. Can't understand while it had dropped back to 10.4v It's funny tho. For the first few mile the bike runs like new.
