1975 z1b Starter Relay... Which Lug?
  • Beatpoet
  • Beatpoet's Avatar Topic Author
31 May 2010 17:25 - 31 May 2010 17:27
#372439
The following picture is how my (near) basket-case Z1 came wired. I don't see very clear pictures in my manual so I can't tell which lug the hot and main fuse is supposed to be tied to and which lug gets the starter. There are also no markings on the relay itself.
I get the feeling that it might be wired backwards...
Anyone?
Last edit: 31 May 2010 17:27 by Beatpoet.
  • Motor Head
  • Motor Head's Avatar
Re: 1975 z1b Starter Relay... Which Lug?
31 May 2010 17:44
#372443
The 2 large posts just complete a circuit to each other when the solenoid is energized. So the starter to 1 and the battery cable to the other, which 1 is no difference.
  • Beatpoet
31 May 2010 21:58
#372527
Sweet.
I put the hot closest to the battery.
  • MFolks
  • MFolks's Avatar
31 May 2010 22:33
#372532
If your starter relay(solenoid) dies in the future, remove it,and visit a local riding lawn mower shop. For about $15.00, a little rewiring and mounting. you can have a good replacement far cheaper than what the bike shop wants.
Be aware that a ground wire may be needed to make it work.
