Dyna Trouble shooting
  • eddiem
  • eddiem's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #63
Re: Dyna Trouble shooting
01 Jun 2010 11:28
#372601
I know I need to learn how to use a ohm's meter it would have helped others to help me.
I just got off the phone with Dynatek Told them what it was doing and how the old rotor fixed it and he told me that sometimes when they make those rotors the magnet gets put in backwards.
They are sending me a new rotor at no charge and to throw the other one away.
Pretty darn good guys to work with I'm very happy with their service.
Thanks again Patton & Omr
Omr...I need to check it out but what's its doing is the test light is very dim when you hookup for the static timing.
With the old rotor the bike fires up now and runs fine
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • eddiem
01 Jun 2010 20:27
#372732
Can anybody recommend a good quality ohmmeter with a low ohms range and does not reverse the polarity of the leads inside the meter ?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Old Man Rock
  • Old Man Rock's Avatar
02 Jun 2010 03:52 - 02 Jun 2010 03:55
#372771
If you have a Harbor Freight Tools, can't beat this little beauty for the money...
Outside of the normal Voltage, resistance and amperage measurements, includes Tach, Dwell, temperature and capacitance all in one fairly cheap priced unit...
If just looking for a decent auto ranging digital volt meter (Voltage, Resistance and Amperage), Home Depot, Lowes, Radio Shack all have Digital Volt Meters for ~ $30...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 02 Jun 2010 03:55 by Old Man Rock.
02 Jun 2010 05:23
#372782
Being somewhat of a dinosaur, I prefer the analog style meters (as shown being used in the FSM's, at least through 1979, and perhaps later years).
Advantages of analog meters include being inexpensive (the example pictured below is about $10), and aren't adversely affected by running engine's ignition system, which may influence readings on some digitals.
I have both analog and digital and invariably reach for the analog when using with the bikes.
For just one example, if a circuit has no resistance, the ohmmeter needle jumps across to max. Easy to see and understand. Like touching the probe tips together (yes, craig, as in tip toucher). And when measuring ohms in an ignition coil, it's easy to read the 3 ohms. Or secondary loop at 15+K ohms.
Same with the voltage readings. I trust that moving needle. Like tach and speedo, simply prefer sweeping needle as opposed to digital readings.
Good Fortune! :)
  • eddiem
02 Jun 2010 20:23
#372986
Thanks Omr I'll check that out.
Patton where would you find one of those? Ebay?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
02 Jun 2010 21:02
#372993
I believe a recent posting indicated availability at K-Mart.
Good Fortune! :)
  • eddiem
02 Jun 2010 21:19
#372998
Guess I missed the earlier post
Thanks
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
02 Jun 2010 21:46
#373002
K-Mart's analog version is in this link submitted in another thread.
seanof30306 wrote:
Good Fortune! :)
  • eddiem
02 Jun 2010 22:02
#373003
Thankz again B)
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • eddiem
16 Jun 2010 21:32
#376249
Got the new rotor installed and timed the motor and runs great.
still going to buy a ohmmeter
Thankz again for the help.
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Old Man Rock
17 Jun 2010 05:25
#376287
Congrats ED....
BTW, those analog meters are fully functional meters for measuring Voltage, Amperage & Resistance... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • eddiem
27 Jun 2010 19:50
#378673
Got one....GB Instruments GMT-312, came with owners manual gonna need that LOL
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
