Advancer Unit ???
  • TeK9iNe
  • TeK9iNe's Avatar Topic Author
  • What did you do!?!
Advancer Unit ???
25 May 2010 11:36
#370812
Hey all.
81 KZ1000 M
Anyone have a pic of the stock advancer?
I think I have an aftermarket one that doesnt quite fit right... its really tight on the pin, and doesnt sit flat/sorta pulls to one side when fastened hard.
Its a little off center and seems to wobble slightly underway. it doesnt cause problems, so far, but who knows...
or if anyone has one, I'd be willing to purchase if its mint!
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
25 May 2010 11:53 - 20 Feb 2013 20:27
#370815
Last edit: 20 Feb 2013 20:27 by H1Vindicator.
  • TeK9iNe
Re: Advancer Unit ???
25 May 2010 12:01
#370817
H1Vindicator wrote:
Searching ebbaayy for 21148-1020 GOVERNOR-BREAKER from the Kaw diagrams....
KZ1000 POLICE 1000 ELR 1100 GPZ SPECTRE ADVANCE BREAKER
OK Cool. Nice pics there...
Mine looks exactly like that, with no timing marks at all on the other side. Guess that was because they came with a factory set timing electronic ignition.
Weird how mine fits so poorly though... Its off center and wobbles... really annoying.
Anyone have any ideas???
:huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
25 May 2010 17:03
#370879
That company was "TEC" that made them. I think they made some for other brands too, probably Suzuki, maybe someone got a similar one from another brand???
Do you have a photo you could post?
  • timebomb33
  • timebomb33's Avatar
25 May 2010 17:13
#370886
is yours the star racing unit if it is they do fit very tightly. as near as i can tell it is to allow more accurate ignition timing.
I THINK MY POWERBAND BROKE
  • TeK9iNe
25 May 2010 19:17 - 25 May 2010 19:24
#370923
I could post a photo, but it would look exactly like the pictures in H1Vindicator's link :P
Guess its the stock one... :blink:
The backside of it that comes into contact with the crank end is not flat. Its sorta convexed towards the center bolt hole. Is this normal? Doesnt seem so.
The whole unit, when held upright in my hand looks like it was manufactured by some drunken 12 year old. Its all crooked and no part of it is parralel with the other side. The whole thing is A-symetrical no matter how you look at it!
:side:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 25 May 2010 19:24 by TeK9iNe.
  • loudhvx
  • loudhvx's Avatar
25 May 2010 19:27
#370925
Sounds like crash damage then. That's very common to get destroyed if the bike goes down on the right side. You should still have writing on it though, and the "TEC" logo.
The end of the crank is what it mounts to. It should be flat, not convex.
  • TeK9iNe
25 May 2010 19:35
#370928
It still has the "TEC" and seems origional.
The crank end is nice and flat, its the advancer end thats convexed and "off"ish.
:huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • loudhvx
  • loudhvx's Avatar
25 May 2010 23:04
#370962
:huh:
Sorry, when I said " it should be flat", I meant the advancer end, that mates with the crank, should be flat.
  • polkat
  • polkat's Avatar
25 May 2010 23:24 - 25 May 2010 23:25
#370964
My KZ750H ('82) and damage on the right side. Knocked the cover off. The advancer still worked but also wobbled a bit from side to side as the engine ran. It wobbled enough that I was afraid the point on the advancer would smack the little bar in the pickups! I took it apart and found that the long bolt that held the advancer to the crack was bent. Bought a new bolt at Napa (a high grade one) and it spun smooth again!
Last edit: 25 May 2010 23:25 by polkat.
  • TeK9iNe
26 May 2010 11:57
#371074
Thats what I figured I would do. Got a new bolt and some nice new screws and lock washers for my Dyna S plate, but when I tucked everything back in there the advance was still about 2mm off center when turning.
If it doesn't come into contact with the pickups, and the advance while riding is crisp, should I really be worried???
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • polkat
  • polkat's Avatar
26 May 2010 12:54
#371104
Well, mine was wobbling more then 2mm before I fixed it, and it worked fine. Looked pretty weird though. It was a new problem for me and I didn't like it, so I fixed it. But yes, I suppose I could have left it that way. If you take it apart again, look on the mating surfaces of the advancer and crank end to see if there's any dirt buildup or gouges/scratches that have raised the metal a bit, and if so then sand or file to knock them down. That could be causing the slight tweak when you install it. Doesn't seem possible to me that the end of the crack itself is bent.
