Kaw electronic ignition vs Dyna S
  • loudhvx
  • loudhvx's Avatar
Re: Kaw electronic ignition vs Dyna S
13 May 2010 14:12
#367703
otakar wrote:
I know that the plates are not the same between the bikes but he coils are identical with identical plugs no mater what bike you had back than.
That's what I've found as well.
The 550 plates should even be the same as the 650/750-4 plates since that part of the motor is basically the same. they can even share timing covers and advancers (not positive on the advancer). I think one of my 550's is actually using a 650 cover right now.
Too bad the alternator side is not interchangeable too.
  • loudhvx
  • loudhvx's Avatar
13 May 2010 14:17
#367705
otakar wrote:
Actually the status on the police pulsers is active. I just looked it up again. The 1133 # is available and has to be because many police departments still have the bikes. They are available in the entire plate configuration for $118 from Ron Ayers and I believe that Z1E could do even better.
Supplier Information [ Close ]
Part Number Add to Picklist (Qty):
Description: COIL-PULSING
Package Quantity: 1
Item Status Code: Active
There must be some difference somewhere then, because the one for 1983 P2 is canceled. Will have to double check some numbers.
  • otakar
  • otakar's Avatar
13 May 2010 14:49 - 13 May 2010 14:50
#367711
You are looking at the 1012 which is superseded by the 1133 and preceded by the 1002. Take a look at the 2005 KZ1000-P24 and it will show you and all of the replacement #s. The final of which is the 59026-1133. It will show you all the #s it supersedes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 13 May 2010 14:50 by otakar.
  • otakar
  • otakar's Avatar
13 May 2010 15:36 - 13 May 2010 15:36
#367727
I just picked up another spare set of 81 GPz1100 pulsing coils on eBay for $21. Just to make sure that I never run out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 13 May 2010 15:36 by otakar.
