charging system diagnosis
  • bobbisman
  • bobbisman's Avatar Topic Author
01 May 2010 16:08
#364776
finally after 2 years i have my 78 kz 650 b running...well sorta. before i put the bike up i had a charging issue which i thought has something to do with the harness that the po had hacked. i have since replace the harness but with the bike running, i notice the battery isnt holding a charge. even when i rev the engine i see no difference. i tried replaceing the stator and regulator/rectifer with used items but never checked to see if they were working properly. what are my steps to chase the charging problem down?
  • Kawickrice
  • Kawickrice's Avatar
Re: charging system diagnosis
01 May 2010 17:06
#364793
First off you need a fully charged battery, then while the motor is running measure the voltage across the battery at about 3500 to 4000 RPM's you should have somewhere around 14.4 volts for a correct functioning charging system.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • bobbisman
01 May 2010 17:56
#364806
ive done this step but it shows no more than 12 volts and doesnt really increase as the rpms increase
01 May 2010 18:02
#364808
Might be an issue with faulty wiring or connector.
Would assure battery terminal connections are clean and snug.
And assure integrity of connection where negative battery cable attaches to rear of engine.
Good Fortune! :)
01 May 2010 18:07
#364811
If needed.
Click > New r/r from Z1E
Good Fortune! :)
  • bobbisman
01 May 2010 18:16
#364815
Patton wrote:
If needed.
Good Fortune! :)
anyone know how to test the regulator/rectifier?
  • bobbisman
03 May 2010 10:01
#365209
so i found this thread...
kzrider.com/index.php?option=com_kunena&...d=4&id=363197#363198
i tested the 3 combinations and im getting about 30 volts on 2 of the combinations and 70 volts on the last. so im leaning toward bad stator? im still wondering how to check the regulator/rectifier
  • MFolks
  • MFolks's Avatar
03 May 2010 14:55
#365246
www.electrosport.com used to have a troubleshooting section, go there and see if they can help.I'm not sure if they cover testing the regulator/rectifier.
