Please Help me fix my bike!
- 74z1900
03 Apr 2006 08:37
Hi,
I have a custom chopper. Its an AMEN frame powered by a 74 z1 900 motor, and I have the following problems.
My wiring harness is too short for the handlebars on it.
I need to install directionals, a horn, and a speedometer to pass inspection. I have no idea how to do this, and the guy at the local bike shop gave me an estimate of 1500 bucks to fix it! Any help at all would be greatly appreciated. Thank you Rob
- Biquetoast
- King Jeremy The Wicked
Re: Please Help me fix my bike!
03 Apr 2006 08:50
Nice chopper. Welcome.
I hope I don't state the obvious when I say to get some shorter bars... of course I don't know *how* short your harness is...
You can certainly find stylish indicators and old stock gages on eBay...
The rest will just have to be soldering in patches of wire to bring the harness up. You're going to have to kow about the fundamentals of motorcycle wiring...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- 74z1900
03 Apr 2006 09:02
I saw some directionals for the z1 on ebay, but they have single wire and dual wire ones. I'm not sure which I need. My wiring harness is maybe 9 inches too short. As far as the bars go, I'm kinda tall, and with the old bars, I had to lean forward, and it was hurting my back, and I figured that since I have a rigid frame bike, I should go easy on my back as much as I can lol. Thank you for the compliment
- Scotty355
03 Apr 2006 09:20
Where are you located? maybe someone can give you a hand.
- 74z1900
- ejshotgun
- 74z1900
- Duck
- e vica na i sau na ga
03 Apr 2006 12:18
Looks nice.
Stick a scale on your tach with speed/gear.
Will save hunting and hooking up the speedo.
How far will it go on that tank?
- fixer5000
03 Apr 2006 12:37
sounds to me like youll have to extend the wiring you need to run the taller bars. get the wiring chart and go at it one by one...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- OldSkool73
04 Apr 2006 17:28
Welcome.....and you gotta love those old skool Z1's in the Amen frames!!!
PM me and we can compare notes....
Later, OldSkool73
Later, OldSkool73
- indykaw77
05 Apr 2006 05:48
Without sounding like a smart-@ss.....do you have the original 74 z1 wire harness?? If so....I'll dig around thru manual and see if I can at least hook you up with what colors are for what. Or maybe someone has the harness scanned and could send you. Check the filebase, too....might be something in there to help you out.
Kawasaki Motorcycles...because cars lean th wrong way!
- 74z1900
05 Apr 2006 06:37
Hi, the bike has the original wiring harness on it.
