GREMLINS - Intermittent Cut Out and Restart
- MentalMike
- God Bless America!
I checked all my wiring and everything seems clean and secure. I kick start her as the electric start is disconnected right now so it can't be a kill switch malfunction. She has a DYNA on her and otherwise has run beautifully and trouble free. I know it wouldn't be coils or spark either, as that would mean poor running and not complete death.
What do you guys think?
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
- Thank you received: 2098
Then connections at both ends of main fuse.
- bountyhunter
- Thank you received: 337
Consider test run with hot wire from batt+ feeding both coils (instead of the dual connector from harness).
Disconnect hot wire immediately after shutting down engine.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Bad coils can do this too, but usually dont until they get scorching hot, like after you stop for a few minutes after a decent ride. Everything under the tank get super hot then, and if your coils are going, they will start cutting in and out.
Anyways... Its an intermittent connection somewhere, so just check all the ones involved. Pull'em apart, scrape/scratch them up till they're nice and shiney, then make sure they fit nice and snug.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MentalMike
Patton, are there any external signs to a main fuse failing? I can replace it just in case, but it would be nice to be able to see it coming.
And both times it happened I had been on the bike for no more that 5 minutes, as it happened at the beginning of my rides.
1976 Kawasaki KZ900
...any external signs to a main fuse failing? I can replace it just in case, but it would be nice to be able to see it coming....
Fuse is probably okay if it looks all right inside, and the connectors at ends are clean and intact.
Am thinking here the problem is most likely either the ignition switch or at splice-in for power wire to Dyna-S.
It sounds like power to both coils is being interrupted. Which at least removes some suspicion as to coils and high tension circuits.
Are a voltmeter and an ohmmeter available for testing?
- MentalMike
Thanks for the feedback, fellas.
1976 Kawasaki KZ900
- Old Man Rock
- Thank you received: 225
Do you have the coil mod installed? :pinch: :whistle:
If so, is it operating and passing ideal battery voltage...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- MentalMike
I've gone the old fashioned way in making sure my wiring and connections were clean and not stealing any voltage.
1976 Kawasaki KZ900
