Speedometer Question
- hocbj23
Re: Speedometer Question
09 May 2010 19:12
Bump. I know its frustrating. I spent 2 years trying to get my Kawi put together from a rollimg chassis and 4 milkcrates full of parts.AND no idea of what it was.Lol.but it can be done.bj
- Zthou1977
10 May 2010 03:17 - 10 May 2010 03:18
hocbj23 wrote:
I have been looking into cable drive, electronic pickups and associated speedometers. The cable drives all have the same part number (checked on kawasaki.com/parts diagrams), so there are no different gear ratios on the drives. I have an 18" instead of a 19" front wheel on my Z1000A, and was hoping to use the drive off of a KZ1000Police. No dice. The gearing inside the speedo is different between the two. For all models with the same front wheel diameter, all gearing ratios in drives and speedos should be the same.Ive got a cable drive,a cable and a 160 speedo. I guess I could remove my elec. drive,hook this one up and answer all our questions, but somebody should have an answer here without going to that much effort.Im too lazy.HELP.lol.bj
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Last edit: 10 May 2010 03:18 by Zthou1977.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
10 May 2010 08:49
As I wrote earlier in this thread, I successfully swapped the original 85mph speedo for a 160mph one, and it works fine. Both are cable driven, and I did not change the sending unit at the wheel.
West Linn, OR
- KZ1000CSRman
11 May 2010 19:47
Wonder where's the pic KZ1000CSRman intended to post.
Maybe got scared and ran for cover. :lol:
Hahaha guys....In the manual, it says the "J, K, and B models are equipped with an electric tach, speedometer, and odometer." So it must mean that the M model have the cable driven stuff. Is this correct?
'82 KZ1000 CSR
- Skyman
12 May 2010 00:33
KZ1000CSRman wrote:
Correct. The M is all cable driven (although I have converted mine to an electronic tach after installing GPz cams with no tach gear)
West Linn, OR
- KZ1000CSRman
12 May 2010 11:32 - 12 May 2010 11:34
A cable speedometer drive unit on the left side of front axle has a protruding male thread designed to accept and spin the lower end of the speedometer cable which connects at its top end to the underside of a cable operated speedometer.
If the speedometer itself has a male threaded protrusion on its underside, that is where a cable drive attaches.
Finding either a speedometer drive designed for a spinning cable attachment or finding a speedometer with a protruding male thread on its underside, or usually both (such as the CSR), means that the speedometer is cable driven (not electrically driven).
A speedometer without a male threaded protrusion on its underside is most likely electrically driven.
Last edit: 12 May 2010 11:34 by Patton.
- hocbj23
12 May 2010 14:59
well Im sending Mr.Chris a 160mph cable driven speedo in the morning. If the damn thing wont work,chris,please send it back.If it does work,please send me the postage and as Mr.Patton so eloquently puts it "Good Fortune." This is all I can do for u at this point.Pass the favor along to another rider who needs assistance.bj
- KZ1000CSRman
13 May 2010 07:16
Oh man, thanks. Sure will pass any favors to others.
'82 KZ1000 CSR
- KZ1000CSRman
19 May 2010 20:48
Hey thanks buddy. I received it the other day. It still is nice. I will try to install it soon. Thank you very much.
Chris
Chris
'82 KZ1000 CSR
