- Thank you received: 1
bad coils???
- spudbudy
- Kick it like you mean it
The reading between the spark towers is 12,000 ohms. I have a spare Green Dyna coils that tests out at .2 ohms on the wire terminals and the spark towers is 15,000 ohms. So I'm left to wonder are my coils bad/weak or is it something else I'm overlooking. I know that the Dyna coils are supposed to be @ 3 ohms so I'm wondering if in fact it is also bad. Any ideas??
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- MFolks
- Thank you received: 540
On the secondary(sparkplug wire ports)side the readings will be between 10.4K to 15.6 k ohms.
Your coils may be failing from heat and/or insulation breakdown.
- polkat
- bountyhunter
- Thank you received: 337
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- polkat
If the windings are shorted together just beyond the terminals, you could get a zero reading, but it's also possible his meter is just off a tad. If bountyhunter's heat up test raises the resistance, then the coils are shot anyway.
- spudbudy
- TeK9iNe
- What did you do!?!
- Thank you received: 28
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
...The spark appears to be very weak....
What voltage is reaching the coil primary terminal?
- spudbudy
- Motor Head
- Thank you received: 391
