no spark when using electric start, kick works.
- paul_the_welder
- hoghaterkaw
- Thank you received: 1
- paul_the_welder
- roy-b-boy-b
- Thank you received: 103
I was helping a friend work on his bike and it wouldn't start. spun over fine. I kicked it one time and it fired.
He had to try as he has never kicked a street bike over. :laugh: Roy
- paul_the_welder
Points bike? When you use the starter you might not have enough fire for the plugs.
Don't know? 1980 model. I figured it was electronic ignition.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- paul_the_welder
You might some corroded connectors along with the week battery. Yes I do agree about the week battery.
You mean weak battery? So a battery could light up the headlight well and spin the motor well and still be bad?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- JR
- Thank you received: 447
- bountyhunter
- Thank you received: 337
Guess how I learned that.....:laugh:
But check the battery first: if the batt voltage drops below about 9 - 9.5V under starter crank, it's probably hosed.
- paul_the_welder
