no spark when using electric start, kick works.
  • paul_the_welder
  • paul_the_welder's Avatar Topic Author
30 Mar 2010 16:43
#357258
1980 kz650. I noticed its really hard to start with electric start.Lately it hasent been starting at all with electric. I checked and its not getting a spark when you engage the starter. I can kick it once and it fires off even cold. Runs good. Any idea's?
  • hoghaterkaw
  • hoghaterkaw's Avatar
Re: no spark when using electric start, kick works.
30 Mar 2010 17:25
#357273
Your battery is too weak. Do a load test. Most likely you need a new battery.
  • paul_the_welder
30 Mar 2010 17:41
#357278
The battery spins the motor well. Way fast enough to start it. Just when the starter is engaged, its not getting spark.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
30 Mar 2010 18:04
#357291
Points bike? When you use the starter you might not have enough fire for the plugs.
I was helping a friend work on his bike and it wouldn't start. spun over fine. I kicked it one time and it fired.
He had to try as he has never kicked a street bike over. :laugh: Roy
  • paul_the_welder
30 Mar 2010 18:10
#357297
Don't know? 1980 model. I figured it was electronic ignition.
  • otakar
  • otakar's Avatar
30 Mar 2010 18:22
#357307
You might some corroded connectors along with the week battery. Yes I do agree about the week battery.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • trianglelaguna
  • trianglelaguna's Avatar
30 Mar 2010 18:23
#357310
switch in clutch lever(if it has one) is /working still/depressing ok????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • paul_the_welder
30 Mar 2010 18:27
#357314
You mean weak battery?B) So a battery could light up the headlight well and spin the motor well and still be bad?
  • otakar
  • otakar's Avatar
30 Mar 2010 18:31
#357319
That is correct. Try to turn off the headlight by pulling the fuse and see if the bike starts than.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • JR
  • JR's Avatar
30 Mar 2010 20:06 - 31 Mar 2010 06:21
#357347
Last edit: 31 Mar 2010 06:21 by JR.
  • bountyhunter
  • bountyhunter's Avatar
30 Mar 2010 23:14 - 30 Mar 2010 23:15
#357375
A weak coil can make a bike really hard to start on the electric starter because the battery voltage dips just enough to starve the spark.
Guess how I learned that.....:laugh:
But check the battery first: if the batt voltage drops below about 9 - 9.5V under starter crank, it's probably hosed.
Last edit: 30 Mar 2010 23:15 by bountyhunter.
  • paul_the_welder
31 Mar 2010 15:55
#357530
thanks for the help guys, I'll check the battery out.
