Reulator/stator testing
  • 2bskor
  • 2bskor's Avatar Topic Author
25 Mar 2010 07:38
#356026
Is there a way...I know there is , I should ask how to check your regulator and or stator(generator). I remember last year one of the fuses getting hot and I did go through a battery last year but it was an old acid type.
kz1000e1 Electronic ignition
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
  • bountyhunter
  • bountyhunter's Avatar
Re: Reulator/stator testing
25 Mar 2010 11:10
#356055
The only good way to test a rectifier/regulator is to install it and see if you get 14V across the battery when you rev to about 2500 RPM.
As for testing a stator, you can check the AC output as you rev the engine but that doesn't test it under load where it may be failing. It will detect an open winding.
  • MFolks
  • MFolks's Avatar
25 Mar 2010 14:04
#356090
Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s).
To check to see if the alternator is working you need to follow these simple steps:
1. Fully charge the battery as this will be the power source during this test.
2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it.
3. Start the engine and let it warm to operating temperature.
4. If you're worried about overheating, position a large fan for cooling the engine.
5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector.
6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3,2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!!
7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced.
Some of the older Z1’s and KZ900’s were phase sensitive, so check the wire colors carefully.
8. Using an OHMETER, Check the three wire combinations again, looking for a reading of 0.36 - 0.54 OHMS. If the readings are above or below, the stator may be bad and need replacement
9. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty.
Inspect the wiring for signs of shorting or overheating too. www.z1enterprises.com sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while.
10. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short(I.E. twisted together with insulation damage).
11. The sprocket cover may have to be removed to access the electrical connectors coming from the alternator and possibly the left foot peg, and shifting lever will have to come off.
