Nuetral switch on KZ1300
  • ffe
  • ffe's Avatar Topic Author
21 Mar 2010 12:15
#355196
Hello-newbie here
I have a kz1300 and it only starts with the clutch pulled in.The nuetral light doen not light either. I did check the bulb and it works-Is there a way to trouble shoot the nuetral switch or? I just don't want to throw parts at it(like I can find them anyway LOL)-Ive had other bikes that the clutch had to be pulled in but at least the light worked.-Is all the clutch-nuetral swith-light tied together,as far as if one don't work none of it works?
Thanks in advance for any help-This site looks awsome!
Doug
Re: Nuetral switch on KZ1300
21 Mar 2010 13:49
#355213
ffe wrote:
Hello-newbie here
Doug
Hello, Doug, and WELCOME to KZR! :)
We're glad you're here! :cheer:
Perhaps a wiring diagram would be helpful.
And there are several right here on site.
Find it by following a few steps as shown in the next successive posts.
Each image may be clicked on to see a larger view.
Good Fortune! :)
21 Mar 2010 13:50 - 21 Mar 2010 14:01
#355214
In the green ribbon, point (don't click) to KZ Information.
Last edit: 21 Mar 2010 14:01 by Patton.
  • otakar
  • otakar's Avatar
21 Mar 2010 13:51
#355215
The neutral switch is simple to check, it is an oppen and close to ground.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
21 Mar 2010 13:53 - 21 Mar 2010 14:03
#355216
Click on Filebase (in the drop-down menu).
Last edit: 21 Mar 2010 14:03 by Patton.
21 Mar 2010 13:53 - 21 Mar 2010 14:05
#355217
Select applicable model year. (Here, I opted for and clicked on 1982.)
Last edit: 21 Mar 2010 14:05 by Patton.
21 Mar 2010 13:55 - 21 Mar 2010 14:06
#355220
Click on particular model desired.
Last edit: 21 Mar 2010 14:06 by Patton.
21 Mar 2010 13:56 - 21 Mar 2010 14:08
#355221
Click on the model that shows a wiring diagram being available.
Last edit: 21 Mar 2010 14:08 by Patton.
21 Mar 2010 13:57 - 21 Mar 2010 14:09
#355222
Click on "Okay" to download the wiring diagram.
Last edit: 21 Mar 2010 14:09 by Patton.
21 Mar 2010 13:58 - 21 Mar 2010 13:59
#355223
Wiring diagram appears, which may be rotated, resized, etc.
Last edit: 21 Mar 2010 13:59 by Patton.
  • ffe
25 Mar 2010 16:54
#356141
Thanks guys-I grounded the wire off the nuetral switch(I assume the sensor under the shifter) and it still did'nt light up?
Doug
  • otakar
  • otakar's Avatar
25 Mar 2010 17:31
#356148
The neutral switch is a ground. You need to measure between the neutral switch and a hot wire.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
