Nuetral switch on KZ1300
- ffe
Re: Nuetral switch on KZ1300
28 Mar 2010 11:24
Ok -Im making progress! I found a broken green wire under the tank-now my nuetral light works fine but I still have to pull the clutch in to start. Can the clutch switch be bad or adjusted? Is there a way to check that?
thanks
thanks
- loudhvx
28 Mar 2010 15:26
ffe wrote:
That's how it is supposed to be, isn't it? That's how it is on most of the later KZ's.
There is a switch on the clutch lever. You can just tie the wires together if you want to bypass that safety function.
thanks
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
28 Mar 2010 15:53
loudhvx wrote:
Yes, this is by design. As loudhvx wrote, you can short the wires, if you want to disable this feature. There should be a connector (probably under the tank somewhere) that connects the wires from the clutch switch into the main wiring harness. You can disconnect the wires, then run a jumper across the connectors on the harness side.
West Linn, OR
- otakar
28 Mar 2010 16:48
I triple those statements. That is by design, yes you can eliminate that by cutting the wires to the clutch lever switch and splicing the two wires together. I however can not think of a single rational reason why you would want to. The reason the switch is there is because too many riders mistake the starter switch for the horn button in a panic and you wind up wiping out your starter clutch or worse.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
