Question about coils
  • emaxxima
  • emaxxima's Avatar Topic Author
17 Feb 2010 15:38
#348845
I have a 79 kz650 that's got under 2000 miles on it, it sat in a garage for about 30 years. I can't seem to get a strong spark even with 12 volts going to the coils, each coil is cracked in 2 places. I looked through the forums, but im still confused as to how properly test the coils.
1979 Kawasaki KZ650
Vernon Hills, IL
  • rstnick
  • rstnick's Avatar
Re: Question about coils
17 Feb 2010 16:13 - 17 Feb 2010 16:20
#348851
Welcome.
You'll want to test the primary and secondary coil resistance values.
Disconnect the coil wires before testing.
Measure the coil primary resistance, using an ohmmeter set at R x 1; measure the resistance between the yellow/red lead and the green or black lead. The value should be 4.0 ohms.
Measure the secondary resistance, changing the ohmmeter setting to R x 100 and measure the resistance between the two spark plug leads (from the same coil). The value should be 23K ohms.
If the coil resistance values do not meet these specifications, the coil(s) must be replaced.
Cracks in the coils are not good. You may be able to get away with spraying an electrical sealer on the cracks, but if the cracks are large, you may just want to source some used or new coils.
Do find a service manual. All the test procedures will be in there.
This shows the coil testing for the 1981 and ON 650s, so the values are different, but gives you an idea on how to hook it up:
img.photobucket.com/albums/v494/rstnick/...itertestingsteps.jpg
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 17 Feb 2010 16:20 by rstnick.
  • rstnick
  • rstnick's Avatar
17 Feb 2010 16:26
#348852
Search for the WG Coil mod info too.
It uses a relay, and some re-wiring, to bring power more dirrectly to the coils, bypassing the kill switch etc.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • timebomb33
  • timebomb33's Avatar
17 Feb 2010 16:49
#348861
if the coils are cracked dont waste much time with them save your self a bunch of trouble and grief and get yourself some new ones. either stock replacement or my own personal favorites dyna tek green 3 ohm coils
I THINK MY POWERBAND BROKE
  • emaxxima
17 Feb 2010 17:34
#348868
Thanks for the info guys
1979 Kawasaki KZ650
Vernon Hills, IL
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
17 Feb 2010 17:40
#348871
Cracks may also be an indication the regulator on the bike is not working correctly. The cracks are caused by excessive heat - something excessive voltage can cause.
With the bike running, you need to check the voltage across the battery terminals. At idle you should get 12.5v-13v. As you bring the rpm up, the voltage should rise and cap at around 14v. If the reading climbs much past 15v, your regulator is toast.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • bountyhunter
  • bountyhunter's Avatar
17 Feb 2010 19:40
#348895
You can't test them properly because you don't have a high voltage arc down test apparatus. They may Ohm out fine but have arcing through the insulation. You can get new EMGO four Ohm replacement coils from Z1 for $36. I wouldn't screw around with a cracked coil.
  • Old Man Rock
  • Old Man Rock's Avatar
18 Feb 2010 04:25
#348919
Junk them coils and save yourself the headache as mentioned by others...
While your at it, spend the additional $120 and get yourself the Dyna-S ignition module from Jeff @ Z1... Worth every penny for once it's adjusted for timing, static and dynamic, forget about it, no point adjustments or condensers to go out on you or no PM required on it... ;)
As for the coil mod...DOH! :dry: With a properly charged battery, if you already have +12Vdc at the coils @ idle and up to ~ 14Vdc at 3Krpm then this mod isn't going to do a damn thing for you... And it definitely isn't going to change/correct for the cracked coil...
Oh no... Not this MOD debate again... :P :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • rstnick
  • rstnick's Avatar
18 Feb 2010 06:16
#348940
get yourself the Dyna-S ignition module & forget about it,
I've had a Dyna fail on me. Lasted a good 7 years or so, but not forever.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • Old Man Rock
18 Feb 2010 07:06
#348955
Good point for nothing and I mean nothing electrical is going to last forever but in most cases will last a reasonably long time...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • nads.com
  • nads.com's Avatar
19 Feb 2010 17:40
#349220
Do you know the output of the emgo coils?
  • bill_wilcox100
  • bill_wilcox100's Avatar
19 Feb 2010 19:36 - 19 Feb 2010 19:49
#349246
Old Man Rock wrote:
As for the coil mod...DOH!... Oh no... Not this MOD debate again... :P :laugh:
OMR
I didn't start the coil mod debate... this time. :blink: :laugh: :laugh: :laugh: :laugh:
At least we always agree on the virtue of good clean contacts and switches. ;)
But FYI, this is how I did mine:
With Points .
With Dyna S .
S Details .
More S details
Best of success, :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 19 Feb 2010 19:49 by bill_wilcox100.
