spark 1977 kz 1000
  • chopperjohn69
  • chopperjohn69's Avatar Topic Author
spark 1977 kz 1000
14 Feb 2010 19:04
#348326
Hi all,
we just put an electronic ignition and dyna coils on a 1977 kz 1000.
When i have the plug pulled still connected to the plug wire i have spark jump to cylinder head an inch away. When i ground it to the cylinder head I lose the spark!! I went back over the wiring and everything seems to be hooked up and wired correctly?
Has anyone had this problem or know whats going on? I had to walk away from it cause im baffled!
Thanks,
Big John
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: spark 1977 kz 1000
14 Feb 2010 19:11
#348328
Is the plug good? Roy
  • chopperjohn69
14 Feb 2010 19:39
#348336
yes sir i tried the same plug on my harley.
14 Feb 2010 21:53
#348375
Wouldn't hurt to again double-check wiring.
Plug wires from left side ign coil under tank attached to outside plugs.
Plug wires from right side ign coil under tank attached to inside plugs.
Black (or whatever color) wire from left (rear) Dyna module attached to left side ign coil under tank.
Green (or whatever color) wire from right (forward) Dyna module attached to right side ign coil under tank.
Good Luck! :)
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
15 Feb 2010 06:14 - 15 Feb 2010 06:15
#348414
Try starting the bike at night (or if you have a dark garage, turning off the lights). You can see where the power is bleeding off (or if it even is) in the dark. I had a KZ1000A with a set of dynas and an electronic ignition...and the bike was missing...after I turned off the lights, noticed that the power was bleeding all over the motor from the area on the coils where the plug wires enter.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 15 Feb 2010 06:15 by Mcdroid.
15 Feb 2010 06:27
#348420
Yes.
And sometimes also helps to spray water mist over the coils and plug wires to augment the errant sparks.
[This time a sponge won't work.] :laugh: :laugh:
Good Luck! :)
  • rainmankz1000
  • rainmankz1000's Avatar
15 Feb 2010 06:32
#348421
Good morn'n Mcdroid i'm rainmankz1000 and i noticed you answered a question my buddy asked. You said that the power was bleeding all over the motor where the coils were. I dont mean to sound ignorant but what does the mean and how can it be corrected??
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
15 Feb 2010 07:11
#348428
It was a short from the coils to the motor block...instead of the power generated by the coils being confined to the plug wires, it was bleeding past the connectors on the coils and shorting to the head. Pulled the coils, removed the plug wires, trimmed any errant copper wires, re-attached to the coils and then liberally coated the area (where the wires attached to the coils) with liquid electrical tape (Dorman brand).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • chopperjohn69
15 Feb 2010 16:10
#348498
Thankyou all for the information, really appreciated it. Im embarrassed to say it was the plugs bad from running so rich i guess. I see why you guys love these bikes. It has single airfilters and a 4 into 1 exhaust so now we need to work on the jetting a bit. Someone suppossedly jetted it already but we arent sure. Can anyone tell me what position the clip on the jet should be at? Rainman and I both will be making profiles and see if we can contribute to the site also.
Thanks again,
Big John
  • Kawickrice
  • Kawickrice's Avatar
15 Feb 2010 16:34
#348502
Don't be embarrassed, its easy to overlook things sometimes, especially on these 30 year old bikes.
Im sure after riding that 1000 you will have been bitten by the KZ bug too. Good Luck and welcome to KZR fellas
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • MFolks
  • MFolks's Avatar
15 Feb 2010 19:34
#348551
The ignition coils that came with the bike tend to break down over time and where they're mounted really isn't the best for cooling.
I'd suggest getting a set of Dyna green (3 ohm) or grey(2.5 I believe)coils if your still running the stock coils.
The stock kawasaki ignition coils had 1/4" wide electrical male terminals, the Dyna coils have 10-32 female terminals that will need screws about 5/16"-3/8" long.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
17 Feb 2010 19:14
#348888
The Jet Needle clip can be in any position your like :laugh: for starters, I would try the middle position.
Your stock Main Jets are: either 102.5, 105, or 107.5
Stock Pilot Jets are: either 15 or 17.5
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
